Service Engine Soon flashing under acceleration
I noticed my engine light flash a couple times under acceleration today but did not stay on or do it again after I noticed it. I've seen it do this once before but didn't think anything of it.
Does anyone have an explanation for this?
Mods: turbo XS TBE, o2 dump, fujita intake, AMS FMI, hard pipes, crushed BOV, Pro Tune (Mike Botti)
What is a tephra knock sensor? Same as a normal knock sensor?
Also, if it's a shift light wouldn't I see it more often? I take it up towards 7k often enough... He he he
Your tune has a patch called TephraMod and one of the features is the check engine light flashes depending on how much knock the engine is experiencing. A slow flash is usually set for a small (1-2) amount of knock, and a fast flash is set for a larger amount of knock.
Thanks for the explanation. I knock is not a good thing. Not sure exactly how it affects the engine but is there something specific that may be causing this? Bad gas? Weather? I haven't changed anything since the day it was tuned so I'm wondering why it would do that.
Thanks!
Thanks!
http://en.wikipedia.org/wiki/Engine_knocking
Knocking (also called knock, detonation, spark knock, pinging or pinking) in spark-ignition internal combustion engines occurs when combustion of the air/fuel mixture in the cylinder starts off correctly in response to ignition by the spark plug, but one or more pockets of air/fuel mixture explode outside the envelope of the normal combustion front.
The fuel-air charge is meant to be ignited by the spark plug only, and at a precise point in the piston's stroke. Knock occurs when the peak of the combustion process no longer occurs at the optimum moment for the four-stroke cycle. The shock wave creates the characteristic metallic "pinging" sound, and cylinder pressure increases dramatically. Effects of engine knocking range from inconsequential to completely destructive.
If it is happening regularly and in a consistent manner through a gear, i would call and have your tuner re-evaluate it. If it is random, i wouldnt worry.
Does it happen more when cold? More when warmed up and youve been driving 20+ miles?
only under WOT?
Mine has the TephraV7 Mod as well, I have the same light, Usually will show under cold conditions (cold motor, =more knock)
I wont drive my car unless warming it up anymore. If im driving in COLD weather, i pick up a couple knocks through the gears as well, if WOT if i haven't been driving the car that long, but it is warmed up to operating temp. After driving 10+ miles, I usually never see the light for the rest of the night. Now as this is random, and not a everyday occurrence, like i said, if you see it everyday and happening in a pattern i would want to have that looked at. I have a Slow flash, for 1-2 knocks, and fast flash for 3-6 knocks. ALSO, i do have 272 Jun cams, which are quite aggressive, which i think might be attributing some phantom knock to this, and tricking the knock sensor. None the less, If you dont have evoscan, and dont know what to look for, call your tuner, and have a professional look at it.
/rantover
only under WOT?
/rantover
Thanks for the thorough explanation. Seems like I shouldn't be too worried. It happened on a fairly cold day with only 3-4 miles on a fairly cold engine. I'll let it warm up good from here out and get some more run time before matting it.
Thanks again guys
Thanks again guys
