need help, tire question
I am the owner of 2014 EVO X GSR
I have 320 miles currently on the clock
I was washing my car today and find out that I have a screw in one of the stock tires so sad that I don't have insurance on the tires
What shall I do
- intall a patch ?
- change tire (since others still like brand new)
if I do a patch will it be safe?
those yakohamas are freaking expensive 450 per tire
Do I really need to swap all 4 tires or I can just put different brand tire and call it a day ?
What shall I do
- intall a patch ?
If its not in the sidewall of the tire, I would bring it to a good tire shop and have them patch it from the inside out. They stick a plug that goes from the inside and it has a sticky surface that bonds to the tire. Worked for me. http://www.fixtires.com/proddetail.php?prod=WW3&cat=16
i would take it to a local tire shop and see if it can be patched (depending on where the screw is) if it can be patched, i would do that. DO NOT BUY ONE DIFFERENT TIRE!! On AWD cars the tires have to be the same size, tread and everything otherwise it can and most likely will mess up the AWD system. so if it isnt patchable, then i would reccomend buying 4 new tires unless you wanna deal with bigger problems
clifhanger87
91
Apr 26, 2010 08:13 AM
DepoRacing
13
Jan 22, 2010 11:39 AM
Neal@tirerack
15
Oct 9, 2007 01:59 PM
morpheus256
Feb 12, 2006 08:20 PM
