Need assistance. Confused with Tires.
Old Apr 20, 2016, 09:58 PM
Mahawka's Avatar
Hey all,
Please excuse my lack of knowledge.
I am looking for new tires for my 2011 MR Stock BBS rims.
After doing my research I decided to go with the Michelin Pilot Super Sport.
I am just a spirited driver. No track.
However, I am confused to which model I should pick.
$360 Part numbers- 69693 P245/40ZR18 93 (Y)
$290 Part numbers- 03264 245/40ZR18/XL 97 (Y)
(I am from Canada. The prices here are ridiculous)
Could you guys please clarify which tire model I should pick ?
What is the big difference between the two that justify the $70 price difference?
Will the "XL" make a huge difference?
Since it's $70 cheaper I am much more inclined to getting the XL. Thoughts?
Thanks all!
Old Apr 21, 2016, 02:04 AM
evo_andrew's Avatar
The more expensive one is a run-flat design and the cheaper one is not.
Old Apr 21, 2016, 03:58 AM
REX7&Z32TT's Avatar
Or you can just get federal 595r and they're super sticky and cheap since you don't track your car
Old Apr 21, 2016, 06:04 AM
Mahawka's Avatar
Are there much performance differences between the flat run and non flat run?
Old Apr 21, 2016, 06:27 AM
shekaar's Avatar
You do not need run flat tires, just go with the normal version.
Old Apr 21, 2016, 06:37 AM
ddawg1130's Avatar
run flat tires are designed for cars that don't have a spare tire. So you can still drive on the tire if you get a flat.
We have a spare, so no need for the run flat. Performance is probably better on the non run flat tire TBH. Or at least the same. I have to assume the run flat tire weighs more.
Save the $70/tire, no point in spending it.
Mahawka (Apr 21, 2016)
Old Apr 21, 2016, 07:08 AM
Mahawka's Avatar
Thanks.
From my research it appears that they no longer make the PSS non run flat version. I could be wrong. I am concerned that the tires I am getting will be old stock. Thoughts ?
Old Apr 21, 2016, 07:21 AM
CaptainCrunch's Avatar
Tires have build dates on them. If no bueno, send them back. And PSS are super popular. Doubt they're old.
Runflats suck. In the cold cause a drumming.
Old Apr 21, 2016, 07:24 AM
Where would you even score a set?
Old Apr 21, 2016, 08:11 AM
evo_andrew's Avatar
I wouldn't worry about getting new old stock tires if that is the tire you are set on buying. When tires are made a coating is applied to them to preserve the rubber until they're installed and driven on.
Old Apr 21, 2016, 08:56 AM
elocinX671's Avatar
Would it save you some money if you can drive over into the US and find the closest Discount Tire store? In Bellingham, WA the Super Sports in stock size cost $767 USD out the door for the set mounted/balanced and taxed.
If it snows often you might want to get all-seasons instead (AS3's or DWS06 come to mind). Or better run the summer tires (Super sports) on one set off wheels and a winter (Blizzaks or similar) on another.
*edit: for some reason I thought you were from BC. The closest store to you would probably be in Kalispell Montana and not worth the drive.
Old Apr 21, 2016, 09:04 AM
Mahawka's Avatar
is the XL 97 (Y) vs 93 (Y) a concern ?
Old Apr 21, 2016, 09:19 AM
elocinX671's Avatar
For the Super sports?
Thats the load rating, get the XL = extra load.. stiffer/stronger sidewall. 93 is for run flat models of Super sport in stock size. Y = speed rating
Old Apr 21, 2016, 12:25 PM
Mahawka's Avatar
Would you guys recommend the 93 or the 97?
Old Apr 21, 2016, 02:35 PM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
93, standard load.
The load index and rating has nothing to do with sidewall stiffness. Its how much weight the tire can hold, and at what air pressure it holds that weight. The OEM tires are 93 standard load. No reason to go higher.
Quick Reply: Need assistance. Confused with Tires.
