Any tips on how to prevent "car jerks" while shifting?
I bought a new evo x a couple days ago and have trouble with the car jerking while changing gears, I can take off smoothly and stop smoothly but when shifting up gears 1-5 it jerks pretty bad. I assume this is bad for the transmission or the clutch? (no clutch smell for a couple days, although it did smell like something was burning the day I got it, maybe cause I drove it off the lot with 0 miles?) I have money set aside just in case. I shift around 3-3.5k, is there anything I'm doing wrong? Should I start to give it gas right before I fully let off the clutch? so that way it's Gas>foot off gas> clutch>shift 2nd gear> some gas before fully let off clutch? Car is completely stock
You really shouldn't be driving it that radically with the shifting to stop 'jerking'. It's a brand new car, so you will have to break in the clutch, etc. Your shifting point seems good for driving around, so that's not a problem. Overall the transmission is notchy, which can be helped by swapping out the fluid.
Other than that.. it's an Evo.. a crude, rude, rough, ground-hugging machine. Enjoy!
It could be you're shifting too slowly and the RPMs drop too much for a smooth re-engagement. The jerking is typically caused by the difference in engine speed and transmission speed after you release the clutch.
Watch the tach next time you drive. If you see the RPM jumping up when you let the clutch out, that's your cause. You shouldn't have to tip in the throttle if you're shifting in a timely manner to be smooth.
If you want to shift super slow; yes you can add a tiny bit of throttle to get the revs back up before you release the clutch but I think faster foot/hand work is a better solution.
On downshifts, blipping the throttle with the clutch out in neutral to rev-match (google double-clutching) can make for super smooth gear changes but, strictly speaking isn't necessary unless you're on the edge of adhesion and need to worry about upsetting the chassis.
Good info here ^. I bought mine brand new as well. Transmission is notchy from 1-4. I changed my transmission fluid after 6500km and the only gear that is notchy now is 3. However like stated above, I tried shifting slowly into third and I find it was actually worse doing that. Shifting faster worked. Hand positioning seems to make a difference as well. Again, its an Evo. Evos has notchy, rough, tough transmissions. It is what it is.
I shift pretty slow, I took the car out today and I've start giving it gas when I only have like 15% left of the clutch to release when shifting, it's been better. 3rd to 4rth gear is smooth, 1st to 2nd is still a bit rough. The car also bogs down and shakes when I shift down a gear, so you think putting it in neutral, revving a little and then putting it in gear is the solution? and my 2nd question is when I am approaching a red light I usually just leave it in gear (2,3,4,5) and just put it in neutral before I completely stop and the car stalls, that should be ok too right?
Just learn, drive and enjoy the car. You'll get the hang of it. Don't over think it. Like others have said, these cars are rough in general. Not as forgiving/smooth as say a honda, nissan, toyota etc....
You will learn with experience how to rev match your shifts so they are smoother. It takes time to learn the car and what RPM's are right for the speed you are going and what gear you are shifting into. So when you shift you want the clutch to have to do as little work as possible to have the engine match the speed the transmission is spinning for the gear you are going into. Notice what RPM your engine is at for a given gear/speed and try and be around that rpm when you are shifting into that gear. This is for smooth shifting, if you are "power shifting" then different rules apply, but those aren't going to be smooth anyway.
No its not ok to let the car stall. you can leave it in gear while decelerating but you need to clutch in before the rpms drop below like 1k or so. If the car is bogging and shaking it means you are lugging the engine, you need to downshift into a lower gear so that the rpms are higher and the engine has a better torque advantage.
It's a tough car to drive smooth. You need to make sure you press in the clutch as you take it out of gear, you need to wait for the revs and trans to synchronization in order for you to insert it into gear and be quick/smooth letting it out. If you are into boost some the car is extremely easy to shift but poodle around town is otherwise a difficult task. Having a background in driving a semi helped me a lot when I got my first manual Evolution, my first was an SST
I assume you know how to reasonably drive a manual trans. Maybe you are running into turbo surge. Read up on it a little and modify your throttle inputs?
well when i shift i usually take my time and that pisses off everyone behind me lol but thats only on 1-2nd gears.. but usually for me i notice at 3200-3500 thats where all my shifts are smooth too
xanderracing
Dec 26, 2006 10:47 PM
