underhood shifter bushings
i recently did the trans (redline cocktail)/transfer case/ and rear diff oil changes along with a short shift install, ams shifter base bushings and the ams 5 speed gate selector bushing.
While that tremendously improved shift all together, i still from time to time get that 3rd gear notchyness,
will the underhood shifter bushing help? or dont even bother ?
Yea true, i'll install those and see what happens.
like i said it doesnt happen as often as it did when it came from factory. Just once in while after the changes and upgrade.
As long as it's not grinding. 3rd gear notchiness is normal for the Evo, its just the nature of the beast.
On that note, I find smooth transitions when I shift to 3rd during acceleration over 3.5k RPM.. I'd say its worth trying it out
I tried the redline cocktail and I thought it was useless. I ended up just doing the redline MT-85 only and it worked pretty well, much better then the cocktail did. But the third gear thing would only pop up when I was being nice to the car. If I was winding out the gears and shifting quickly into the next, never had an issue.
Yup exactly, thats the only time when i have that issue. When shifting beiow 3k rpm it has notchyness, if i shift above 3k its fine.
I did use 2 quarts of MTL and 1 quart of MT-90 (map performance recommended that) and that definitely improved shifting.
Ralliartize It
Mar 25, 2013 12:06 AM
Spec-Ops1
12
May 20, 2011 09:12 AM
sekula
Jan 7, 2010 04:17 PM
mx4life85
Nov 28, 2008 09:35 PM
DangerousDan
Sep 21, 2006 05:12 AM
