Exhaust to turbo bolt keeps coming loose
Old Aug 15, 2017, 08:18 AM
ChipperEvo's Avatar
Hey all,
I wanted to see if anyone else has had any experience regarding the manifold bolt that keeps coming loose.
Out of the 4 bolts, only the bottom left corner one keeps coming loose.
I know bolts can loosen from heavy/hard driving but mine seems to come loose when under normal driving.
If the other 3 are tight, will it cause any leaks with that 1 bolt loosened up?
I am trying a locking washer to see if that helps.
Old Aug 15, 2017, 08:33 AM
splattj's Avatar
Lock washer might help. Re-torquing to spec when the manifold is hot also helps.
Old Aug 15, 2017, 09:36 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Replace the gasket, and the bolts. Torque to 45ftlbs. And use the OEM convex spring washers. FP sells them. You use 2 per bolt like this
==()==, shouldn't have issues anymore.
Old Aug 15, 2017, 10:05 AM
ChipperEvo's Avatar
thanks guys. I will try that.
JoshB
Apr 18, 2015 09:18 PM
spoolinx
11
May 31, 2013 12:19 PM
Derek888
Oct 10, 2005 06:30 AM
adotwhite
Apr 7, 2005 10:54 PM
EvoRs
Sep 22, 2004 01:14 PM
Quick Reply: Exhaust to turbo bolt keeps coming loose
