Evo X radiator shroud: To keep or not to keep?
I was cleaning my engine bay today, removed the radiator shroud and cleaned that area underneath since it was pretty bad. After it was all nice and cleaned, I thought that I kind of like the way it looks. Is anyone aware if there would there be any negative impact to keeping the shroud off? besides dust which i don't mind cleaning when I wash the car but more along the lines of cooling or if anything would not work as efficient as it was intended? I'm no expert, I just don't want to sacrifice efficiency for impression. (Now I really want to upgrade that upper intercooler piping.)
It's there to keep the air from hitting the radiator and traveling up and around the radiator. Hence it is called a radiator shroud. If you're the hard-park Evo type then go for it. If you actually drive the car hard or live in a hot climate you may regret your decision.
Am I living in Lala Land here and it makes no difference ? Or is it the same with the shroud on but with the snorkel removed?
IMO, the car looks unfinished and cheap without that piece installed. It also serves to help direct air to go through the radiator instead of over it. Same thing with the trim pieces in the bumper that cover the intercooler end tanks. Never understood why people remove those as well.
bigben
Jan 3, 2010 07:10 AM
