-   Evo X General (https://www.evolutionm.net/forums/evo-x-general-250/)
-   -   Can't lock doors w/ turbo timer (https://www.evolutionm.net/forums/evo-x-general/344665-cant-lock-doors-w-turbo-timer.html)
WWevoX May 10, 2008 05:20 PM
Hey everyone, any input would help.
I can't lock my X with the turbo timer still counting down!
I think this might have something to do with the FAST key entry system.
I posted this on socalevo and no answers and I've talked to the shop foreman at South Coast and he said he's going to look into it.
Just curious if anyone might have found a fix for this.
Thanks
ak47po May 10, 2008 05:23 PM
Car probably won't lock doors with the car running so you can't lock yourself out,that being for cars without your setup.
funks May 10, 2008 05:49 PM
I guess there's some logic in the ECU to prevent the car from locking when it's still on via FOB. Only the dealerships would probably have access to change the settings so they are most likely your best bet.
It's probably safer just to unhook the turbo timer for now though :) lol.
WWevoX May 11, 2008 01:11 PM
well hopfully they figure that out and can do somehting about it.. i know i am not worried about locking my keys inside..........
i just shut my turbo timer off for the time being...
thanks for ur info
DoHBoY May 11, 2008 01:24 PM
The fastkey system on my GTS will not allow you to lock the car with it running/with the key in it. Its part of the anti-moron system {thumbup} im only guessing its the same way with the X
dek0026 May 12, 2008 06:27 AM
you can't lock the car when inside it manually with the car running.
JohnnyBoy427 May 13, 2008 01:23 PM
Do you use the button on the door handle to try and lock it or do you use the button the the knob. Reason I'm asking is because our 07 altima won't lock using the button the door knob while running but WILL lock if I hit the button on my keyfob. try that maybe?
Ridge Racer May 13, 2008 01:57 PM
I keep a spare key in my wallet in case I lock my keys in. I would just disable it and put a key in your wallet. A friend of mine has a jeep grand cherokie, he can't shut his door with it running or it will lock. I don't think thats rite, shouldn't it only lock after 5 mph?
silver9mr May 13, 2008 02:04 PM
yea just lock your doors by hitting the butten on the door on your way out when the turbo timmer is on and youll be fine
WWevoX May 18, 2008 12:28 PM
I can't lock the car by hitting the black button on the outside handle...
I can't lock the car by pushing the lock button on the inside with the door open, when you do that it auto unlocks right away...
And I've been talking to the shop foreman at South Coast Mitsu and seeing if I can just have the feature shut off in the ecu, I've never lock my keys in my car. Plus you don;t have to take the keys out of your pocket so you shouldn't lock them in the car in the first place..
Still doesn't make sence if there are sensors in the car looking for the key and if its not there it should allow you to lock the car with the FAST key.
Also if you use the emergency key, you can lock the car with no problem just like in the VIII and IV's.
I don't like the idea of leaving something in the ignistion just in case I need to use the key, but there has to be a way around this, it seems like its such and easy fix........
And the car doesn't lock automatically when the car moves...
TheShortBus May 18, 2008 12:34 PM
i dont remember if my 03 oz wouldnt lock while running. but ive had my ecu flashed since then. ive also gone turbo, and i have a greddy turbo timer and dont have any problems with it
kinloch99 May 18, 2008 01:05 PM
another reason not to waste money on a turbo timer
janvin21 May 18, 2008 08:36 PM
hmmm... I just install an apex turbo timer on my X and there's nothing wrong with it, I can lock my X while the engine is running, I don't know how you set up your turbo timer, mine is working fine.
WWevoX May 19, 2008 02:15 PM
maybe it can be the hks type 1???
i used the stock harness for the evo 8 and 9, direct plug and play... maybe for the 10 there is a different wire or somthing, and thats only if ur apexi wire harness is made specifically for the evo 10........
sucks cuz the car is still to new and no one has **** made specifically for the 10 so its hard serching the interent for answers...
WWevoX May 19, 2008 02:18 PM
oh and i also tried locking the car with it running and the turbo timer off. and it still didnt lock, it could be because the harness is connected and i dont wanna take the time right now to un plug it...
im just trying to eliminate possibilities
