Roof rack fitment found
Hi All,
As I've mentioned in other posts, I needed to figure out a roof rack fitment so that I can get my mountain bike to the trails. Mitsu USA doesn't offer one, and neither Yakima or Thule list a fitment at this time. Mitsu Japan has one in their catalog that is obviously a Thule, so the proper "fit kit" clips and feet pads obviously exist. I had most of the parts for a Thule roof rack system already, so I went to my local bike shop and Gander Mountain with the car, a trace of the roof rail contour, and picture of the JDM rack and went through every kit that I could find to see if any matched up. In the end I found Fit Kit #2120, which is listed as being for '03+ Toyota Corollas which appears to be the ticket. I test fit everything carefully and I think it is just about perfect. The angles and length on the clips match the Evo X's roof rails perfectly, and the feet pads are the correct width and have the right "shoulder" location, though to be absolutely perfect they would need to be slightly angled to match the way that the rain gutters angle outward a bit in the front. There are markings inside the door rails that designate the center of the foot location, and if you look that section is slightly straightened in order to accommodate the clips. I covered the areas where the feet and clips touch the car with clear-bra material, cut the crossbars down to the fit nicely, and mounted it up. The fit kit comes with two slightly different styles of the clips. The only difference is that one set is very slightly longer. I used those in the front. It also comes with a set of "spacers" that position the clips up higher in the towers, but those were too high for this application so I left them out. It's on there very solidly and nothing is digging in or binding anywhere, so I'm happy with it for now. When Thule releases an official kit I'll change over to that - unless of course they end up specifying this same kit... I initially mounted up a fairing, but after thinking about how amazingly thin the roof panel is I removed it. I was concerned that the fairing might push down on it's feet enough at highway speeds that it could end up denting the roof. It looked better with the fairing on, but it isn't worth risking. Mitsu doesn't show the fairing in the JDM catalog, which might also suggest the fairing isn't a good idea. I'll take some pictures and post them tomorrow. --Josh |
Please Josh if you can post some pictures and comments about this, as I have the same problem (I actually don't own the X yet so it is an important buying factor). I usally carry 2 MBs and a windsurf... do you think the fit kit that you found is strong enough? I also have a Thule rack so I just need the fit kit.
Thank you! |
I just replied to your PM with more details but forgot to mention that I won't be able to take any pics until I get back from the RallyCross in D.C. early next week. I'll take some good pics for you then.
any issues with damage to the aluminum roof? I want to put a rack up for snowboards.
Originally Posted by adrock1559
(Post 5776202)
Sounds like a NICE RACK!
(I couldn''t resist) |
Josh, did you ever get any pics of the roof rack taken? Would greatly appreciate it. Thanks... - Ron.
are roof racks removable once you install them?
Originally Posted by Ronsoc
(Post 5885663)
I'm sorry, I haven't had the rack back on the Evo since the first test fitment. I'm hoping to go riding on Thursday, so as soon as I put it on I'll take plenty of pics. --Josh |
Originally Posted by theho1
(Post 5885684)
Originally Posted by JWA
(Post 5890116)
Yes, they simply grab onto the roof rails and then you release them to remove the racks.
so when you remove the racks, the rood just looks like a regular roof with nothing attached right? |
Thanks
Thanks... Have a good ride, Ron.
(Post 5896792)
are these rails the ones that are built into the roof itself?
so when you remove the racks, the rood just looks like a regular roof with nothing attached right? I could try to explain how they mount, but it'll be easier to understand in pictures. My ride today got canceled, but I'll mount it up in the next day or two to get the pics for you guys. Nothing is mounted permanently, when you remove the rack, which takes a couple minutes total, it is completely back to normal. |
I actually went out and did the same thing, except i own a evo 8 RS. This kit fits pretty well on the steel door rails. so there isnt any part touching the aluminum roof.
One thing is you probably need 2 people to make it fit correctly i couldnt tension mine without having one side slide. but that might be not getting the correct bar width. But anyways it works with the Thule kit for the evo's roof profile. Cheers |
