Any MR's having idling issues
I did a search of idling issues and I noticed that the GSR's had some earlier problems but that was fixed by a reflash. Well I just bought my MR tonight and noticed after I left the dealership the car wasn't idling well. It almost stalled out a couple of times and it went down below 500 rpms several times and the idle was very sporadic. I guess I will be calling the dealership in the morning. My question is am I the only MR having this issue? Also did the reflash fix the idling issue on the GSR? Thanks
Not mine.
Hmmmm......not mine either :confused:
Originally Posted by Sixspeed J
(Post 5897504)
Could this be something other than needing a reflash? Possibly some piping that may have become loose? I know it sounds crazy but I had my wife drive the car down the drive at about 35mph very moderately I will add (very early break in) and as she takes her foot off I swear hear the recirculating valve blow off my wife heard it as well. I'm totally stock so could I really be hearing this??? Also the idle seems to be even more eractic than earlier. I know I'm just grasping at straws now but I just trying to understand what going on.:confused:
Also I just found out the headlights are going to have to be realligned.:crap: It seems my car is a little crosseyed. |
I Forgot to mention it hasn't thrown any codes yet.
No idle issues here, picked mine on up Tuesday.
No idle issues here either. Idles at approx 900rpms. Picked up mine almost 3 weeks ago.
Thanks for the responses. Problem has hopefully been fixed, a vacuum hose had slipped off.
no problem so far....600 miles delivered 7-7
No idle problems with mine, a good tuner can fix that easily. There are many things that may cause it, the DV could be loose, maf not fully plugged in, lose clamps/pipes, vaccum lines as mentuioned before. Check everything over thats the first step.
I just picked up my MR on sunday and haven't noticed any idle issues since I brought it home. I'll keep watching it to see if anything creeps up....
Little over 700miles on mine and no issues.
Fixed!!!
It was the Vacuum line!! Car feels great !! Idles the way it should now!!{thumbup}
(Post 5902384)
haha, if you had owned a DSM prior to this you would have had this problem fixed in the first 10 min. ;) Nothing taught me more about trouble shooting a turbocharged internal combustion engine more than my 93 TSI{thumbup} |
