| yorT |
Nov 22, 2010 06:57 PM |
Cruise Control won't work when cold outside
So I recently had to replace my master cylinder and now whenever I try to turn cruise control on when cold outside it won't work. I have to actually pull up on the clutch pedal and then hit "SET" to get cruise control to work. When it's warm outside I have no problem getting cruise to work. Also I used to have some leeway pressing the clutch while cruise was on before it cuts off. Now when I barely touch the clutch with cruise on it cuts off instantly. Any ideas on how I can adjust the pedal so the cruise switch sticks out further? I know it's not the most important thing but I use cruise control ALL the time.
