My projectors lights don't work properly....
Does anyone know why my OEM projector don't work. Basically my lights work when the car is off, but when i start the car and move a little bit my passenger side light doesnt work, and the drivers side lights doesn't turn off either when i turn the switch off... just somethings to know, i painted the oem housing black so i baked it and all that stuff.....
Did you keep the cover on the back for the hid bulb area?
Originally Posted by 4b11powered
(Post 9106026)
while it was in the oven?
(Post 9106053)
Originally Posted by kkmoslehpour
(Post 9106152)
you mean the plastic black cover? i took it off..
(Post 9106276)
Did you use a damp cloth on the underside of the light housing? Was there any water or condensation after you re-heated them?
your lights dont work because you put them in an oven
Originally Posted by lancerarmstrong
(Post 9106796)
so what is the problem? i kinda know what the problem is now, once i swapped the balast the other side seem to be not working, also i was wondering if it has anything to do with the connectors? the projectors i bought seems like it has fewer pins in the conector to connect to the car relay its self, and when connected tmy DRL dont work but one of the HID dont turn off either when i turn the switch off from the inside... is there some kind of adapter i have to buy since i amd changing from halogen light to projector HIDs?
Where did you buy the lights?
(Post 9108593)
wow
Originally Posted by sun_ice4
(Post 9109595)
| All times are GMT -7. The time now is 01:08 AM. |
