What is the annoying rattling noise on the driver's front side???
It sounds like something is rattling on the front left side. I brought it to the dealership today and they heard the noise but can't find it.They checked everything and they found no loose parts.
It happens when I drive over uneven roads and/or small bumps at 30mph or less. It sounds like metal to metal rattling? This has been happening for a few weeks. Any ideas??? |
Inside the car or outside? If inside, check behind the A-pillar cover.
It usually caused by the plastic dash rattling against window. Try holding down the dashboard next time it rattles to check.
Originally Posted by Evo Tengoku
(Post 9358772)
Originally Posted by icethug
(Post 9358871)
I had a similar metal on metal sound that only happened around 1500 RPM. Turns out it was under the hood.
I have the same issues!! it's annoyin! until
I Blast the ROCKFORD sound system lol... try that |
May be the pillar, may be the dash? I have a rattle in the rear right side that I haven't figured out where that is coming from. The shifter cable rattles when in 5th gear going over 65mph. The glove box rattles. It never ends...
Originally Posted by teamnemesis3
(Post 9364318)
I Blast the ROCKFORD sound system lol... try that I hope Mitsubishi works on these rattling issues for future cars... we shouldn't have to chase rattles like this. |
I have this on the passenger front, like metal rattling. Haven't looked to see what it is. Be nice to know.
Originally Posted by iceman1680
(Post 9359319)
I know my panel under the steering wheel rattles at certain RPMs. Might check that one also. I have not got around to pulling this off to see what I can do to fix it.
1 Attachment(s)
Originally Posted by garcias2k
(Post 9373819)
Originally Posted by ptakats
(Post 9375021)
what did your problem end up being? my car does it at 3k and it sounds like a combo between a loose bolt and heat shield vibrating but i cant figure it out either, it just started
I give up. I can't find the rattle. It sucks.
I have a rattle in the same area but as its a JDM on the RHS( Drivers ) .
After looking for weeks i have narrowed it down to where the Drivers front quarter panel joins the engine bay & is bolted in , pretty much where the hood sits when closed If you look at it and tap the thing it sounds tinny and slamming the drivers door you can hear the rattle . I wedged rubber/foam strips in there and it definatly stopped the noise however there are a few areas where it rests Metal on Metal. Hope that makes sense .... |
| All times are GMT -7. The time now is 10:14 AM. |
