-   Evo X General (https://www.evolutionm.net/forums/evo-x-general-250/)
-   -   Any safe tunes that don't void warranty? (https://www.evolutionm.net/forums/evo-x-general/592138-any-safe-tunes-dont-void-warranty.html)
mj0917 Jan 6, 2012 02:21 PM
Bought the car July, so far i've only worked on the exterior (Carbon Fiber Hood, Carbon fiber lip spoiler, mud guards)...any tunes to improve performance without voiding warranty? thanks
Boostfiend Jan 6, 2012 02:35 PM
The OEM tune is the only tune that doesn't void warranty.
SamsonEvoX Jan 6, 2012 02:43 PM
Modifying any car is like playing with fire. Sometimes you get burned, sometimes you don't. From my own personal experience, it depends on the dealership. I had a modded G35 and a modded Civic Si and still kept my warranty. However, I have been a loyal customer to this particular chain of dealers owned by the same person. I have always been super polite and courteous to service managers and have even bought them gifts when they serviced my car. Customer loyalty to important to some dealerships, so they will often work with you. Bottom line is to go reasonable on the mods and don't even think about bringing your car to get fixed under warranty if you blow up the motor...
mj0917 Jan 6, 2012 02:47 PM
pls elaborate on reasonable mods? sorry man i'm such a noob :)
evo jason Jan 6, 2012 04:02 PM
I'm just planning on some bolt on mods and a tune, nothing too crazy.
EcuFlash
ETS Intake
ETS Upper/Lower IC Pipes
ETS Recirculated O2 Eliminator Downpipe
ETS High Flow Cat Test Pipe
ETS V2 Quiet Exhaust System
Grim Speed 3 Port Electronic Boost Control Solenoid
Edit: The downpipe and high flow cat will almost certainly void the warranty.
SamsonEvoX Jan 6, 2012 04:14 PM
Cat-back, intake, UICP, LICP, intercooler, possibly a test pipe or downpipe. Beyond that, when you go with cams, different turbo etc., most dealers see these things as problematic. But like I said, a lot depends on the dealership.
mj0917 Jan 6, 2012 08:01 PM
@Jason...I was like why the hell would they zoom in on my pic...then realized it was your avatar hahaha ...me go to corner now
mj0917 Jan 6, 2012 08:03 PM
damn i guess my car will be a virgin for now...can't really afford it if something happens. some guy in the other forum or this forum can't remember which...had to rebuild for 8k ouch!
carbonair Jan 6, 2012 08:16 PM
ill be waiting to mod the car till the car is paid off. only makes sense in my mind. That way if something does go wrong i can afford the grand or two grand no problem. No car payment equals money in the bank.
manofdafam Jan 6, 2012 08:17 PM
Just do UICP, intake and a catback with the cobb ap tune. These are easy mods to install and uninstall in case something goes wrong.
bandalgom78 Jan 6, 2012 08:44 PM
1. Go buy Access Port.
ECU reflash is best way to increase power anyway.
Also, When it comes to service you can go back to stock ECU.
2. Cat back exhaust also ok. There is no way that dealer can prove that cat back exhaust will damage engine.
3. Don't install Intake or any internal aftermarket parts in engine bay if you worry about warranty. It will avoid warranty, period. Dealer might say ok when you do service, but when you have problem with engine and they saw intake, then you are out of luck.
For me,
I don't trust dealers...F Them....
When stock parts break, it is time for stronger parts to replace!
dgarcia41982 Jan 7, 2012 03:19 PM
I don't have much and have nice numbers. Plus easy to undo.
TheBlade Jan 7, 2012 03:26 PM
/me reads topic
http://thesource.homelinux.net:8080/...y/facepalm.gif
At least you are asking before doing. Like people said, if you flash the ecu, you have voided your warranty. Also remember that if you flashed with an access port, and then something breaks, and you put it back to stock, it's just going to appear a little unethical.
