Evo X - Model Year Differences
Recently there was a thread in Evo X general that began to describe the differences between 2008, 2010-12 Evo X models. Unfortunately, it looks like it was not only closed, but completely removed from the site.
Google caches: Page 1: http://webcache.googleusercontent.co...&ct=clnk&gl=us Page 2: http://webcache.googleusercontent.co...&ct=clnk&gl=us Here's another example of a mod shutting down this informative topic: https://www.evolutionm.net/forums/ev...ges-evo-x.html There are a few threads here and there that describe the differences between 08 and 10, but i don't see anything for 11 or 12 or in one comprehensive spot. I propose we start an official sticky that lists all changes for each model year, and continues to add information as the years progress. I'm sure we'll keep it much more accurate than random google searchers or trying to piecemeal info from random threads. And the the mods want, they can combine similar threads. Just a thought :thumbup: |
between 2011 and 2012 i think the interior panel changed from the faux carbon fiber to piano black.
Originally Posted by davey111483
(Post 10235671)
between 11 and 12 i think the stock muffler on the 2012 was slightly alter to be louder maybe slightly more free flowing in the muffler right ?
Originally Posted by denlin68
(Post 10235714)
2008- had a horribly rich stock tune. Red taillights, and red LCD screen on the dash. It also had flat grey plastic on the A/C knobs. The diff pins were made with a softer metal than Mitsu should have used and some have had failures. The 2008s also came with aluminum valve covers. Only GSR and MR models available.
2010- Mitsu upgraded the taillights to the Ralliart/black tails on the 2010+ models. Side skirts were changed to prevent the rock chips that occurred on the 08s without the Aero kit. They also changed the LCD screen to color and added chrome to the A/C controls. The Touring model became available for the MR- Full Leather, while the GSR "SE" model was released for it's one year run. The valve cover was changed from the aluminum one to a plastic valve cover. The leather on the steering wheel was changed. The stock tune was vastly improved of the P.O.S. tune from the MY08s. 2011- The timing chain began to be upgraded to the new one, and the diff pin issue was resolved. "FUSE" was introduced. The 2011+ spoiler was slightly altered, and the "high" spoiler was made standard. Since the spoiler was now standard, the SSS package was changed to the SS package and the SL package (sunroof and leather) was introduced to the GSR. One of the tubes on the coolant overflow bottle stopped coming on the car. The exhaust was redesigned to make it a little louder and to make more power. Mitsu got rid of the sensors on the door handles that unlock the car when using the Fast Key. Evos 2011+ with fast key, you have to use the button on the door. Again, the tune was improved. 2012- tune was improved again, although there are some instances where the 2012's aren't making quite the power of previous models, although it is mostly rumors now since the 2012s have not been out as long. The "Piano Black" dash panels from the MRs were made standard on the GSRs. The Aero kit from Mitsu was changed- The side skirts no longer come with the Aero kit unless you order them separately. On the Evos without the SS package(HIDs and projectors), the DRLs were disabled. The door panels were made more "plush". |
Originally Posted by ugakirk
(Post 10235901)
2010- Mitsu upgraded the taillights to the Ralliart/black tails on the 2010+ models. Side skirts were changed to prevent the rock chips that occurred on the 08s without the Aero kit. They also changed the LCD screen to color and added chrome to the A/C controls. The Touring model became available for the MR- Full Leather, while the GSR "SE" model was released for it's one year run. The valve cover was changed from the aluminum one to a plastic valve cover. The leather on the steering wheel was changed. The stock tune was vastly improved of the P.O.S. tune from the MY08s. 2011- The timing chain began to be upgraded to the new one, and the diff pin issue was resolved. "FUSE" was introduced. The 2011+ spoiler was slightly altered, and the "high" spoiler was made standard. Since the spoiler was now standard, the SSS package was changed to the SS package and the SL package (sunroof and leather) was introduced to the GSR. One of the tubes on the coolant overflow bottle stopped coming on the car. The exhaust was redesigned to make it a little louder and to make more power. Again, the tune was improved. 2012- tune was improved again, although there are some instances where the 2012's aren't making quite the power of previous models, although it is mostly rumors now since the 2012s have not been out as long. The "Piano Black" dash panels from the MRs were made standard on the GSRs. The Aero kit from Mitsu was changed- The side skirts no longer come with the Aero kit unless you order them separately. The door panels were made more "plush". |
(Post 10235901)
Originally Posted by surefooted
(Post 10237000)
Also, somewhere between 2008 and 2012, Mitsu took out the sensors in the door handles for fast key and now only provide the button.
Originally Posted by ImEv0
(Post 10236988)
can you elaborate on the plush door panels?
(Post 10237024)
The door panels on the 2008-2011, atleast I think it is up to 2011, Evos without leather are made of a material that I would call rat hair or something like that. Kind of like a cheap, fake suede and the panel is kind of stiff and hard.. gigadee. The 2012s came with a plush or cushioned door panel/insert.
(Post 10237000)
it's a great feature. |
(Post 10237239)
so u cant unlock your doors by simply placing your hands on the handle? that sucks...
There also appears to be a power difference in the 2012 over the previous year’s affecting tuning - see existing thread:
https://www.evolutionm.net/forums/ev...-variance.html |
there is no power difference my car baselined at 252 on a mustang dyno same as every other bone stock evo x on this same mustang dyno(over 20 cars). With a tune, exhaust and air filer I am at 300. Same as comparable modded evo x's on this dyno. Until someone can give an acutual difference in parts I will not believe they made the 2012 with less power it makes no sense to do so.
The car is still slow though lol. |
