-   Evo X General (https://www.evolutionm.net/forums/evo-x-general-250/)
-   -   How do you reset the driver's window? (https://www.evolutionm.net/forums/evo-x-general/711794-how-do-you-reset-drivers-window.html)
Pargy Apr 20, 2015 07:14 PM
My driver's window is messed up, the auto roll up/down doesn't work and the window stops 3 times when I roll it up. I have to let go of the stitch and pull it up again to get it all the way up.
I've tried a ****load of times/ways to reset it but I can't get it to work.
I've read that you need to roll the window down and hold the switch for a few seconds, then roll it up without stopping and do the same. The problem with this is the window stops 1/3rd of the way up every time. I've also tried it the opposite way, starting at the top, and that doesn't work either.
Am i just doing it wrong?
MercuryMR Apr 21, 2015 06:46 PM
roll & hold the window button until the window rolls all the way down and keep holding the button for about 10 seconds or until you hear a click, then repeat the process when rolling the window all the way up and hold the button for ten seconds or until you hear a click, then release. This should fix the problem with the short-stroke of your window.
__________________ or check a manual this happened to me before I think this will work.
redbackLahiru May 10, 2023 07:27 PM
i have the same issue.my Passenger/Assistant side won't rolled up. same like yours it moving 1/4 and stop. did you get you slove the issue?
