-   Evo X General (https://www.evolutionm.net/forums/evo-x-general-250/)
-   -   Evo X MR won't start (but will crank) (https://www.evolutionm.net/forums/evo-x-general/714500-evo-x-mr-wont-start-but-will-crank.html)
TurboTJ Jun 10, 2015 08:21 AM
I got in my 2013 Evo X MR today and tried to start it up. It ran with a rough idle for maybe a second or two but then died. After this, I have been unable to get it to start again.
I smell gas, so I'm pretty sure it's injecting fuel (but don't know if it's the right mixture). I have 32,XXX miles on it and it was running fine last night, so I think the compression is good.
The check engine light remains on when I just leave the ignition on - does this always happen or does this mean I have a CEL code?
Does anyone have any ideas of what could be causing this? Should I try to fix it or should I just have it towed to the nearest dealer?
Thanks for the help!
--------SOLUTION-----------------------------
When I called the dealer, they said I could trying pinning the gas peddle to the floor and cranking it. The peddle has to be all the way down which apparently tells the ECU to shutoff fuel and allowed the car to start (at which point you let off on the peddle)
Napalm_Enema Jun 10, 2015 08:36 AM
You could try replacing the fuel relay. Do a search it's a fairly common component.
If you do tow it, FLATBED TOWTRUCK ONLY.
BlueBlurSTi Jun 10, 2015 08:38 AM
Since you are near the end of your bumper to bumper I would have them take it in. Have them look everything over well, check for oil leaks etc.
superawd Jun 10, 2015 01:25 PM
check the vacuum line for fpr
zebra4 Jun 11, 2015 01:42 PM
Flooded. The last time you started it, did you let it warm up? Or just start it to move it then shut off right away? This has happened to me around 4 times. Worst case, pull plugs, take lighter to them to burn excess fuel. When car is first started, it dumps fuel to keep cold engine running properly. If you don't let it warm up, this can happen. CEL will be on when the ignition is on, but car not running, does not always mean there is a code.
zebra4 Jun 11, 2015 01:45 PM
Also, try holding the throttle all the way open (WOT) while cranking. This is supposedly going to drain cylinders of fuel.
TurboTJ Jun 15, 2015 09:39 PM
Thanks! This is what worked!
I called the dealer the day this happened and they told me the same thing. I went home and tried cranking the car again (10 hours after it didn't start the first time) and it still didn't start. I pinned the throttle to the ground which apparently tells the ECU to shutoff fuel and the car sputtered to life.
The dealer blamed the issue on water in the gas and it being flooded, but I'm still not sure. I would think that the car sitting there for 10 hours would cause any gas to evaporate, but who knows.
dfarmer0033 Dec 27, 2017 03:50 PM
Sorry for reviving a old thread but is this a real thing? I started my car yesterday to move it in my drive way for just a second. Next morning it wouldn't start at all. Checked all relays and fuses. Can't hear the pump but definitely smell gas after cranking. I have a 2010 RA if that makes a difference but I suspect it does not.
AIZevox Jan 29, 2018 08:22 PM
Had same problem before and solve it with same way. Just don’t know why it happened. Some one knows?
