-   Evo X General (https://www.evolutionm.net/forums/evo-x-general-250/)
-   -   RPM's jump when clutch is engaged (https://www.evolutionm.net/forums/evo-x-general/736374-rpms-jump-when-clutch-engaged.html)
Abrevo Jan 9, 2017 04:42 PM
So recently I've noticed that when I step on the clutch, the RPM's slightly jump. This happens on a cold start. It goes away after the car is warmed up after driving it for a bit. Anyone else experience this or know why this happens?
Thanks
dk3Jdefje1X Jan 9, 2017 04:52 PM
Thanks
yes, I experience it, pretty sure it's normal
Abrevo Jan 9, 2017 05:00 PM
Alright, thanks man
Pal215 Jan 9, 2017 05:27 PM
You mean on cold start and at idle? Yeah it's normal. Once you start the car the rpm's jump high and drop very slightly when you let go of the clutch pedal. That's just the inertia being added by the input shaft and gears from the transmission side when your drivetrain is engaged.
-pal215
