Side Skirt Hanging
Anyone know how to fix This? I tried a zip tie but it won’t stay flush. I change the bracket behind it and still won’t mount right. Those brackets suck bad btw. The clips on he bracket don’t even go in. Yes I know the mess on there. Previous owner had it like this. I tried to reinstall them but no good. New to the Evo aswell.https://cimg1.ibsrv.net/gimg/www.evo...cff6e1c60.jpeg |
Are you sure that it is sitting in there correctly? There should be a "slot" where the little ledge should fit in to (by ledge I mean the section that has those 3 rectangles cut in to for the tabs.
I had a similar issue when it came loose after I ran over a huge chunk of ice that the car in front decided to unload in the middle of the road last winter. Was sitting like that until I fitted it into the "slot". Didn't even have to put in new tabs for the 3 holes. sits very flush now. |
Im gonna try to reinstall it. You install from the front first right ? Yeah those little holes for the tabs don’t even fit in either side |
I didn't even have to take it off but i'm sure it helps to just reinstall it.
I just used a flat head screw driver to lift up the ledge area over the "slot". Sorry to keep calling it a slot but I don't know how else to describe it. |
I tried to lifting but still nothing.i will still try some other time when I have time. That is annoying me lol. The tabs on the bracket don’t even grab either. I couldn’t really see the slot. |
