Recaro install - SRS reset help in AZ.
:( - Well I did something wrong installing Recaro's in my FE so I have the SRS light.
Anyone in AZ that can reset this for me without having to go to the dealer? |
Do the Recaro's have the airbag? If not, there is a guide out there to put a small fuse in there to trick that sensor and disable that light.
Originally Posted by Napalm_Enema
(Post 11829695)
Originally Posted by bolothedv
(Post 11829689)
Originally Posted by J-ROC
(Post 11830496)
You'll have to install seat belt buckle from your stock FE seats onto the Recaro's. I had the same issue on my FE.
https://infoanalytics.tools/metric/?...=1531931643996https://infoanalytics.tools/metric/?...=1531931643996https://infoanalytics.tools/metric/?...=1531931643998 |
(Post 11831440)
Yeah, I installed the belts, but after I reconnected the battery and started the car once. So it sounds like you had your SRS light pop on. Did you go to the dealer or figure out another way to reset the SRS?
Did you swap this entire piece out from you OEM seats to the new Recaros ?
https://cimg6.ibsrv.net/gimg/www.evo...eccb9b7dfd.jpg |
