Pre Purchase Advice, Mod List Help.
HI GUYS!
All I want for christmas is my first EVO. I found a 2013 evo x gsr with 51k miles, one owner. Here is the mod list I am aware of: Clevite rod bearings manley turbo tuff rods je pistons manley valve springs titanium retainers kelford 214b cams straight pipe exhaust upper/lower intercooler piping hks bov 2lb lighter flywheel stage 3 xtd clutch eibauch lowering springs The rod has arp fasteners and has arp2000 head studs I am looking to buy an evo as a daily driver. What do these mods tell you about the car? Should I be apprehensive about buying? Is there something I could check or take it in for a full inspection? Thanks. |
Originally I wanted to buy stock as I thought that is the safest and most reliable route, and add on all the bolt ons myself. After getting some stock cars inspected, I found they have issues as well. I widened my search to cars with the bolt ons. These mods seem a little more extreme to making the engine capable of higher horsepower. Can these make the car more reliable, or is it more likely it has been raced and beaten? Just want an evo that is fast, fun, and reliable when cared for properly. All help is appreciated! Thanks.
Originally Posted by DesertDog57
(Post 11851847)
HI GUYS!
All I want for christmas is my first EVO. I found a 2013 evo x gsr with 51k miles, one owner. Here is the mod list I am aware of: Clevite rod bearings manley turbo tuff rods je pistons manley valve springs titanium retainers kelford 214b cams straight pipe exhaust upper/lower intercooler piping hks bov 2lb lighter flywheel stage 3 xtd clutch eibauch lowering springs The rod has arp fasteners and has arp2000 head studs I am looking to buy an evo as a daily driver. What do these mods tell you about the car? Should I be apprehensive about buying? Is there something I could check or take it in for a full inspection? Thanks. Yes, I would be apprehensive a buying a car that has been modded. I would ask who tuned it and get a shop to look to see if the parts are on correctly and do a compression test. |
engine rebuild with ~50k on the clock, thats a red flag, especially without the other mods to justify that kind of work.
I do not think these are the only mods, it certainly has all the bolt on as well. Here is a link to the car: https://www.selectmotorswichita.com/...2/Details.aspx
They dealership is taking it to the shop for a full inspection and compression test. Here is a link to the vehicle, https://www.selectmotorswichita.com/...2/Details.aspx. Apparantly the check engine light is on due to the catalytic converter being removed, is that a common occurance?
(Post 11851918)
I wouldn't be too worried about a used tuned car with bolt ons if everything seems done right, but I wouldn't buy a second hand car with a built motor if I wasn't the one that built it. Once you open up the motor I think you are just opening yourself up to more potential headaches. |
