Putting away car for winter... Tire ramps?
Well it's winter here in NY and it's getting to the point where I'm putting my car away for the winter.
So, I usually winterize my car by throwing in some fuel stabilizer to a full tank and by plugging my car into a battery tender. I was thinking of adding tire ramps this year. What do you think of these Bunkerwall Tire Ramps? Does anyone use ramps? Or are they a waste? My mindset was that for $60, I would get some piece of mind that my tires won't go flat during the 5 or so months my car is out of commission - especially since I have to garage it in a facility that I cannot access until springtime. |
Pump the tires up to max pressure on the sidewall and they'll be fine. Radial tires don't flat spot in just a few months.
Lots of opinions on this topic if check on YT.
Most do say that flat spotting is a non issue. Some put the car on jack stands to relieve the suspension / tire loads Some cap off exhaust pipes to prevent rodents We certainly have enough cold weather guys, on the boards, that can give you advice |
Jack stands if anything, ramps is the same as leaving it on the ground.
I have stored my X every winter since 2014. I have always parked the car using 'normal' street pressures and never experienced any flat spotting.
Car is parked in a non-climate controlled garage (though I don't think I've ever seen below freezing temp in there), on a concrete floor. |
Originally Posted by Prime12
(Post 11852267)
I've used race ramps flat stoppers for the past few years and zero issues the car is normally away from november-march
I never understood this... it's a AWD car designed for such.. why is it put up for the winter as if it's a RWD car? Do they suck in winter time, or is this were the wrx is better?
Originally Posted by Robert Wesker
(Post 11854476)
I’ve used race ramps to store for over 6 months...my tires stuck to the ramps and trying to separate the ramps were damaged. plus Race ramps state not to store on for long periods |
