Intermittent Cruise Control
I have an an issue with cruise control I recently fitted in sometimes it can be switched on and sometimes it can't.
GSR SST FQ300 I have noticed a couple of things, some of which from the forums: 1. I have aftermarket rear LED lights fitted (not by me) 2. I noticed that the cruise control dash light went off when my headlights came on in auto mode 3. If I turn on ignition without starting engne for a period of time (e.g. adjust dashcam, program aftermarket DAB) on starting engine I lose cruise control. In this case it is only able to be switched on after a long period of ignition off I strongly suspect from forums that the LED rear lights are to blame due to resistance issues, especially given 2 above. I have tested brake switch and it is adusted correctly. My question is twofold: Is it the rear LED lights causing the issue? Does any one have a definitive resistor value to put in series for LED rear lights to so that resistances matches stock lights? Thanks. |
Originally Posted by simondo
(Post 11875310)
3. If I turn on ignition without starting engne for a period of time (e.g. adjust dashcam, program aftermarket DAB) on starting engine I lose cruise control. In this case it is only able to be switched on after a long period of ignition off |
