MAPerformance Evo X Catch Can Available NOW!!!
We know you have been waiting and we are happy to say that the MAPerformance Evo X Catch Can / Coolant Expansion Tank is in-stock and available for purchase! Price: $499.99
Get yours here: https://www.maperformance.com/produc...-maperformance https://cdn.shopify.com/s/files/1/08...4576.jpg?26699 We've been hard at work developing the best catch can for the Evo X community! All that boost in your 4B11T generates a lot of crankcase pressure which can lead to pre-detonation and be detrimental to the performance and longevity of your engine. Our all-new MAPerformance Catch Can for the Evo X is a full vent to atmosphere catch can is designed to eliminate this crankcase pressure. Venting the crankcase properly makes seals & gaskets last longer and reduces oil accumulation in intercoolers and intake piping to ensure your intercooler is operating at an optimal level. It also reduces the resistance against your pistons and is able to free up some hp that your factory system robs you of. https://cdn.shopify.com/s/files/1/08...7477.jpg?26699 *Install picture above is of a prototype, we do not offer a raw metal finish on this product. Our sleek billet design replaces your plastic coolant overflow tank and doubles as your coolant overflow tank and catch can, all with an easy single bolt install. https://cdn.shopify.com/s/files/1/08...4582.jpg?26699 Features: Single bolt-in design with no major modifications or special tools needed for install Sleek billet aluminum design with shared factory level coolant overflow tank Built-in level float for easy to check coolant level High-Quality Squirrelly Performance fittings and lines included -10AN lines for reduced airflow velocity Stainless steel filler to assist with oil collection Drain kit available for easy emptying of system with no hassle or specialty tools needed 100% Direct Fit Made in the USA Benefits: Relieves damaging crankcase pressure Improved life of seals and gaskets Reduces oil coating the inside of the intercooler and piping Frees up hp from relieving crankcase pressure https://cimg1.ibsrv.net/gimg/www.evo...9b9a0e7587.jpg You know the benefits of a catch can for your Evo X, why not have a clean billet design with high-quality parts from MAPerformance. Click HERE to pick one up for your Evo X! Please call us with any question or to learn more. |
