EVO X RS Control Cruise Install and Activation
Hi, I need install cruise control in my EVO X but is RS, I bought the steering wheel switch on ebay, but it doesn't work, it doesn't turn on the green light on the dashboard, I have to do something in my harness, any suggestions?
Steps I did: buy the switch, plug it into the steering wheel (turn on the backlights, well connected). Then verify that it was active in bit # 1, but it still does not work, there is no green light on the panel
Check out this thread:
https://www.evolutionm.net/forums/ev...installed.html
The RS might have the clutch and brake switches in place for other ECU functions so it may just be reprogramming.
Hi Eric
Any answer from you, I found out we need 4 pin brake switches but our wire harness only connects 2 and the clutch switch is jumpered, still can't get cc working, no green light on dash cc
Help
CrackaBoi
15
Sep 6, 2008 09:38 PM
Diavlo
Aug 31, 2007 02:25 PM
