Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Request: Hella Supertone horn Install
Old Dec 14, 2012, 06:37 PM
  #61
ogrenator's Avatar
Originally Posted by Metal
I'm pretty sure they'd work fine if you install both, I just don't know where you'd install the second one. The space up front is very limited, and you really don't want to block the radiator any more, I don't think. Plus, one is PLENTY loud, just wait till you hear it.
There is a writeup I found for a lancer...I assume the structural metalwork is pretty similar in the front...he bent one of the brackets and used and existing screw to bolt it down...I would have to pull my shroud to get a pic...that's why I was hoping to see yours to I could make up my mind
Old Dec 16, 2012, 07:39 AM
  #62
Mrmcjay's Avatar
I pulled the shroud on my '13. There is very little room however I might have found some spots for symmetrical mounting.
Post a pic of your setup.
Old Dec 16, 2012, 05:11 PM
  #63
Metal's Avatar
Alright guys, per request, here are some pictures of my basic install. I'm pretty sure this is as simple as it can be. I have no idea where you'd stick the second horn
Let me know if you have more questions.
Request: Hella Supertone horn Install-qogcu.jpg
Request: Hella Supertone horn Install-tsrkq.jpg
Request: Hella Supertone horn Install-cfcxa.jpg
Request: Hella Supertone horn Install-3fnmv.jpg
Old Dec 19, 2012, 11:17 PM
  #64
bricel24's Avatar
I managed to mount both horns with some bracket bending and trimmed away some inner plastic shrouding (does not show from the top at all). I know they're not symmetrical, but I don't care, I don't have OCD and it's not a show car. It had seen more cones than car show judges.
Old Jun 11, 2013, 01:14 AM
  #65
yy89's Avatar
Can u post some pics from the front? Is there another method of removing the plastic cover (that does not involve cutting)?
Old Jun 11, 2013, 04:22 AM
  #66
tkromer's Avatar
Here's a no cutting install:
One is using the stock mount, the other I grabbed a piece of perforated aluminum angle stuff (not sure the real name), bent a little "U" to space it out from an existing bolt.
Old Jun 11, 2013, 06:57 PM
  #67
Rall1boy's Avatar
Off topic but i like your teeth. Im going to be doing something similar. What did you do for mounting points?
Old Jun 24, 2013, 05:46 AM
  #68
tkromer's Avatar
The teeth have a couple threaded rivets through them with a washer and nut on the back holding them in.
Old Aug 20, 2017, 07:33 PM
  #69
EastWickEvo's Avatar
Does anyone know how or what is the best route for connecting the power wire from relay to battery, since the battery is in the rear of the Evo X?
Old Aug 24, 2017, 09:41 PM
  #70
So does the EVO X have a secondary horn? Also, was the single horn loud enough as if you do not need second horn for decent functionality?
Old Jan 17, 2018, 01:16 PM
  #71
evoguy4242's Avatar
Very helpful
Old May 21, 2018, 10:08 PM
  #72
mvm42699's Avatar
Location: 85296, 99519, 96817,98310,07306,10461(HomeSweetHome), & 00739
Secondary horn is located underneath the driver side headlight. on the right hand side of the intercooler if facing the front of the car. Looks exactly like stock one that is in the front. Late reply LOL
Old May 16, 2019, 04:37 PM
  #73
AdamDeMamp's Avatar
thanks for info
Old Apr 22, 2020, 05:08 AM
  #74
jd8888jd's Avatar
Bump
Ok, please someone confirm to install these Hella Horns do you?
Need Relay
Dont need a Relay
Thanks
Old Apr 22, 2020, 06:34 AM
  #75
splattj's Avatar
You do not need a relay. They draw 12A on the factory 15A circuit.
I managed to get mine installed in the center of the grill using a piece of aluminum flat stock but it did require some plastic air guide trimming.
Quick Reply: Request: Hella Supertone horn Install
