Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Wideband Install Question
Old Mar 27, 2009 | 02:51 PM
Grendelrt's Avatar
I am going to install a wideband hopefully next weekend. I was planning on following the boost gauge install for part of it. Does anyone have any advise on how to hang the wiring from the test pipe back into the engine bay. Any advise on snags people found when they were doing theirs? Any general info would be helpful thanks!
Old Mar 27, 2009 | 02:55 PM
goofygrin's Avatar
I would *not* follow those instructions as they'll have you running wires all over the place (I started down that path, but the guy I was doing it with pointed out that having wires all over the place wasn't necessarily the best idea).
I pulled the cable from the sensor up through the same grommet as the primary o2 sensor. The LC-1 control module is behind my center console. I ran the serial cables to the glove box and ran the gauge into the cubby below the ac controls. We tapped power from the cig lighter and there's a ground right there in the center console that we used.
Everything is clean and nicely tucked away.
Old Mar 27, 2009 | 03:19 PM
Grendelrt's Avatar
I didnt even think about following the stock O2 hehe. I think I might mount it on the steering column or the dash in the back corner. Do you have any problems seeing the gauge in that location? I did the AEM UEGO btw, dont know if that matters. Thanks for the reply.
Old Mar 27, 2009 | 03:56 PM
goofygrin's Avatar
Well, it's not like I watch the wideband constantly, but I can steal a glance when I need to to see how things are looking. I know some people put them in their glove box (why?).
Even if you ran it to the dash or column, going through the primary o2 grommet will be a lot easier and safer.
Old Mar 27, 2009 | 04:36 PM
Grendelrt's Avatar
Cool thanks man
Old Mar 28, 2009 | 04:28 PM
ryanowarrior's Avatar
dang i didnt even think to run it through my stock O2 groment, good idea thought
Old Jan 14, 2010 | 11:53 AM
JaxRRevoX's Avatar
question, what fuse should I wire my 12volt wire to for my UEGO? I have my boost gauge 12volt going to my "lighter" fuse.
( I had a UEGO once b4 but sold it, I actually ran my wire up underneath the passenger seat, underneath the carpet and around the console & up onto the steering column. I just cant remember what fuse I had the 12volt wire going to )
Old Jan 14, 2010 | 03:41 PM
evolvedx's Avatar
I pretty much did exactly what goofy already said, but my WB is the AEM like yours. I'm tapped right into the back of the cig lighter for power. No issues. Placement will be fine.
Old Jan 15, 2010 | 07:31 PM
yorT's Avatar
With this WB are you able to log with it using EVOScan?
Old Aug 18, 2011 | 10:01 PM
duhveed's Avatar
Sorry to bring this back from the dead.
But can someone answer the bolded part??? Please thanks
Old Aug 19, 2011 | 03:13 AM
armysoldier1073's Avatar
this might help.....
https://www.evolutionm.net/forums/ev...eband-afr.html
Old Jan 27, 2012 | 09:41 AM
BravoZero's Avatar
evolvedx, what gauge pod is that? That's a perfect spot to mount one.
Old Jan 27, 2012 | 10:26 AM
TurtleRA's Avatar
A neat little trick is if you flip the lid of the ash tray up, the aem wb will fit perfect on it, just wedge it on between the bolts and the cable connectors. The benefit of this is you can easily remove it to tuck in the cubby so would be thieves can't see it.
TEXAS TRAVISTY
Outlander Sport
58
Feb 25, 2021 05:48 PM
MrFreddieA
Apr 10, 2015 09:45 AM
Rokpapaziz
11
Jun 6, 2013 12:30 AM
xmel012
Nov 28, 2012 09:13 AM
dahuii77
Oct 7, 2011 12:21 PM
