How to install SSS spoiler on a Canadian GSR with GTS spoiler...help!!!
wow that sounds kind of simple i think the sss spoiler have a extra hole. spoiler bends in on my gts only has 2 holes drilled on each side so more then likely you would have to drill a extra hole get the spoiler and just line it up and drill the holes. fill the holes with epoxy or something. to keep it from cracking the paint. Then Done Spoilers are a easy install
ok cool...so no need of a little foam between the spoiler and the trunk where the holes are.
Cuz when they installed my evo spoiler on my previous Ralliart 2005...they put a little thin foam so I thought I had to do the same with the SSS spoiler.
thanks for your advice man!
The gaskets are $5 CDN each (Left & Right versions) from the Mitsu dealer.
You'll need to make a few extra holes and plug up the existing unused ones.
We're doing the same on my GSR.
you have to drill two more holes...the hole on the top (which is bottom when you pop the trunk) extends further than the GTS spoiler..and you have to drill another hole which is the "middle further out hole"
Lightsaber
May 26, 2016 02:46 PM
