Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Race harnesses
Old Mar 15, 2010 | 11:56 AM
weneversleep's Avatar
Originally Posted by Pr3z
http://soloracer.com/rallye4.html
These bolt in. There is no specific Evo application though.
Note that these harnesses, being 4-point (even though they have ASM, they are not specifically designed for the Evo application), are not allowed by some HPDE organizations, including Porsche Club of America.
Old Mar 15, 2010 | 01:36 PM
goofygrin's Avatar
So far I've used these with SCCA Solo and other autocross applications (no big deal), two local drivers education groups, BMW CCA and NASA.
Noone has batted an eye (although the instructors almost always are pleased to have a set on their side). I do know that BMW CCA requires the instructor to have the same restraints available as the driver (ie. if you have a harness the instructor needs one too).
Old Mar 15, 2010 | 02:09 PM
chu's Avatar
chu
I installed the Schroth Rallye 4 ASM last night, great harnesses. I dont think you'll have a problem anywhere, as long as you have some type of asm device with the harness. The great thing about the schroth is that they use oem mounting locations, and the rears separate from the front section to accommodate rear seat passengers when off the track.
Old Apr 25, 2010 | 07:17 PM
pips's Avatar
Solution
Originally Posted by 2.0TEASE
hey guys,
just installed my new harnesses and wondering how to turn off the beeping of the stock seatbelt warning since i wont always be using it.
thanks in advance
For ppl who have installed aftermarket race harness and want to get rid of beeping Seat Belt Warning.
I use Schroth 3pt w/inertia reels in my X (and they work great btw). But the EASIEST way to rid your eardrums of the dreadful beep- I use these male seatbelt "slugs" to fool the computer and voila, no beeping They work perfectly...Pm me I can hook you up
Old Apr 25, 2010 | 07:57 PM
ZEKE010's Avatar
i use these
http://gtfabrications.com/sabelt-rac...ck-p-8347.html
fia approved. dont need it here but no one will hassle you if its fia.
Old May 4, 2010 | 07:30 AM
Ah10's Avatar
only problem with Rallye4 is you wont be able to use hans device, if you want to use hans device then you need to get Profi II FE ASM
Old Aug 14, 2010 | 12:22 PM
overboostin's Avatar
you can shove a few quarters in it lol
Old Aug 16, 2010 | 01:20 PM
alex3dworld's Avatar
whatever Harness are you going to use, if you are going to use/buy a harness bar, don't buy anything but AMS. i have it and the fit is perfect. i went first for some bar from ebay and it was a piece of cra.....
Old Aug 24, 2010 | 06:44 AM
Johnr352's Avatar
I use a 6 point Sabelt, with a HANS. Holds me in so tight I want to cry a little...
Old Sep 23, 2010 | 12:37 PM
importerok's Avatar
HMS is where I order all my safety equipment.
http://www.hmsmotorsport.com/store
Old Sep 24, 2010 | 08:11 AM
Johnr352's Avatar
Except that they (AMS) no longer make one... Option is the NRG or Sparco. Both seem pretty well made.
Old Sep 24, 2010 | 08:19 AM
migs647's Avatar
That's sad I was looking forward to getting that bar.
I don't see an Evo X sparco bar?
Old Mar 22, 2011 | 05:24 PM
Subi.convert's Avatar
best way is to remove the plug and depress the spring loaded sensor. Then tape it up in the depressed position with electrical tape and zip tie it under the seat. Then you can remove the buckle arm all together. I have my driver side disabled just so I can drive short distances without my belt on.
Aniel
May 11, 2016 09:49 AM
LOVEMYX
Aug 24, 2015 01:57 PM
EvoPauly
May 18, 2015 08:32 PM
theblackbeast11
Feb 26, 2013 07:39 AM
motion3131
Jul 28, 2010 03:35 AM
