Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Start / Ignition Wire Diagram Knowledge
Old Jun 6, 2010 | 09:46 PM
R0ME0's Avatar
Does anyone know which or have a wiring diagram for the starter wire and ignition wire on the SSS X? Thanks in advance. Also I read that the ignition wire or starter wire is different in the SSS where the power is constant or something? Please let me know trying to clarify some wiring issues. Thanks!
Old Jun 7, 2010 | 04:09 PM
R0ME0's Avatar
No One?
Old Jun 7, 2010 | 04:42 PM
Dennis F's Avatar
**Test everything first with a multimeter** I am not responsible for this information, just passing along what I have in my database.
Battery YELLOW (+) IGNITION SWITCH HARNESS
Ignition 1 WHITE (+) IGNITION SWITCH HARNESS
Accessory 1 LIGHT GREEN (+) AT IGNITION SWITCH HARNESS
Starter 1 ORANGE (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense RED/WHITE (OPEN) IGNITION SWITCH HARNESS
Tachometer GREEN/WHITE (AC) AT ECM MODULE ON DRIVER SIDE OF AIRCLEANER ASSEMBLY
Speed Sense BROWN/WHITE (AC) AT ECM MODULE ON DRIVER SIDE OF AIRCLEANER ASSEMBLY
Parking Lights YELLOW & BROWN (+) CONNECTOR UNDER FUSEBOX
Brake Lights RED (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights WHITE/BLUE (+) AT MODULE UNDER DRIVER SIDE DASH
Horn GREEN (-) AT MODULE UNDER DRIVER SIDE DASH
All Door Trigger
Domelight Super YELLOW (-) AT MODULE UNDER DRIVER SIDE DASH
LF Latch YELLOW (-) AT CONTROL MODULE UNDER DRIVER SIDE DASH
RF Latch GREEN (-) AT CONTROL MODULE UNDER DRIVER SIDE DASH
LR Latch RED (-) AT CONTROL MODULE UNDER DRIVER SIDE DASH
RR Latch BLACK (-) AT CONTROL MODULE UNDER DRIVER SIDE DASH
Trunk Trigger BROWN/WHITE (-) AT MODULE UNDER DRIVER SIDE DASH
Power Unlock GRAY (-) IN HARNESS IN DRIVERS KICKPANEL TO DOOR
PowerLock YELLOW/RED (-) IN HARNESS IN DRIVERS KICKPANEL TO DOOR
Driver Mtr Unlock RED (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Driver Mtr Lock BLUE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Pas Mtr Unlock RED (REV) IN HARNESS IN PASSENGER KICKPANEL TO DOOR
Pas Mtr Lock PINK (REV) IN HARNESS IN PASSENGER KICKPANEL TO DOOR
LF Window Up BLUE (REV) AT DRIVER WINDOW CONTROL SWITCH
LF Window Dn VIOLET (REV) AT DRIVER WINDOW CONTROL SWITCH
RF Window Up BROWN (REV) AT DRIVER WINDOW CONTROL SWITCH
RF Window Dn GREEN (REV) AT DRIVER WINDOW CONTROL SWITCH
LR Window Up WHITE (REV) AT DRIVER WINDOW CONTROL SWITCH
LR Window Dn BLUE (REV) AT DRIVER WINDOW CONTROL SWITCH
RR Window Up GRAY (REV) AT DRIVER WINDOW CONTROL SWITCH
RR Window Dn YELLOW (REV) AT DRIVER WINDOW CONTROL SWITCH
Sunroof Open YELLOW (-) AT SUNROOF CONTROL SWITCH
Sunroof Close GREEN (-) AT SUNROOF CONTROL SWITCH
Headlights-Lo VIOLET (-) AT MODULE UNDER DRIVER SIDE DASH
Headlights-Hi GREEN (-) AT MODULE UNDER DRIVER SIDE DASH
LF Pk Lt Bulb GREEN (+) AT FRONT LEFT HEADLIGHT ASSEMBLY
RF Pk Lt Bulb WHITE (+) AT FRONT RIGHT HEADLIGHT ASSEMBLY
LR Pk Lt Bulb YELLOW (+) AT REAR LEFT TAIL LIGHT ASSEMBLY
RR Pk Lt Bulb BROWN (+) AT REAR RIGHT TAIL LIGHT ASSEMBLY
All Hazrd Lights GREEN (-) AT VEHICLE HAZARD SWITCH
LF Hazrd Bulb RED (+) AT FRONT LEFT TURN SIGNAL ASSEMBLY
RF Hazrd Bulb LIGHT BLUE (+) AT FRONT RIGHT TURN SIGNAL ASSEMBLY
LR Hazrd Bulb GREEN (+) AT REAR LEFT TAIL LIGHT ASSEMBLY
RR Hazrd Bulb WHITE (+) AT REAR LEFT TAIL LIGHT ASSEMBLY
Parking Brake LIGHT GREEN (-) A VEHICLE PARKING BRAKE
Trnk Release GRAY (REV) AT VEHICLE FUSEBOX
c900t16
Dec 24, 2020 05:13 PM
KenyonKanye
Oct 2, 2016 05:20 PM
Blue_05EVO
Jan 17, 2013 07:15 PM
R0ME0
Feb 25, 2011 10:00 AM
blackfly
11
Feb 23, 2010 11:04 AM
