Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
AUX cable help
Old Jul 20, 2010 | 07:00 AM
08redevox's Avatar
AUX cable help
I just picked up an 08 Evo X with the rockford system minus the Nav. How do I use the aux connection in my car so I can stream pandora in the car? I picked up an aux cable that goes red/white cable to 3.5mm jack.
Old Jul 20, 2010 | 07:14 AM
TJs98GT's Avatar
you plug the red and white side into the car and the other side into your audio device and then push and hold the cd button on the left to put it into AUX mode and VOILA!
Old Jul 20, 2010 | 07:15 AM
MAS2377TECH's Avatar
From: Philly, Germany, Japan, UK...South Dakota (Da Sticks).......
You should just be able to plug it up and hit the AUX button on the system and play Pandora through the speakers. That's what I do.
Old Jul 20, 2010 | 08:00 AM
CatalystGod's Avatar
once you plug the audio Y cable to your device and the car, you need to keep the CD button depressed until you see "AUX" on your display. Start playing music from your aux device and it should just work.
Old Jul 20, 2010 | 10:30 AM
stageup's Avatar
just turn up the volume on your aux device almost to max
i couldn't hear **** until i did, just adjust volume from the deck at that point
Old Jul 20, 2010 | 11:19 AM
TJs98GT's Avatar
i suggest testing sound quality first, some audio devices on MAX will reduce quality and cause distortion, a couple clicks shy of max and then turn it up on the radio may sound better
Old Jul 20, 2010 | 04:09 PM
stageup's Avatar
hehe that's why i said almost max
my sony mp3 player maxes @ 30, i have it at 25
Old Jul 20, 2010 | 06:22 PM
08redevox's Avatar
That worked thank you
Old Jul 21, 2010 | 03:36 AM
E6-X's Avatar
yeah it might have distortion and a whine/airplane kinda noise when no music is playing from aux device. it goes together with your throttle when the player vol is high. SUX !
Old Aug 13, 2010 | 02:29 PM
tofumann's Avatar
$hit...my question is...where are the holes?? I've the car for almost two years and I didn't know of this function. Got the same model and trim like yours...
Old Aug 13, 2010 | 03:24 PM
BPAuto's Avatar
Silver Sponsor
Should be in the compartment at the bottom of the center dash -- right in front of the ash tray. There is a small flap that says "AUX" that you need to flip open and you should see the AUX hookups.
- Jason
__________________
"Let us help you build your JDM dream!"
www.bulletproofautomotive.com
The Real JDM - Interactive (blog)
Email: sales@bulletproofautomotive.com
Direct North American Dealers for Voltex, Mines, Varis, First Molding, HKS Kansai, Cusco, HKS, Advan, Volk, Ings+1, C-West, Work, and so much more...
Old Dec 19, 2010 | 06:15 PM
oreoevo's Avatar
Yea i get static thru mine..kinda sucks
Old Jan 4, 2011 | 03:25 PM
talek's Avatar
If you get static, pick up a ground loop isolator. PAC makes one that just plugs between your aux cable and your device, filters out almost all of the high frequency distortion.
Old Jan 4, 2011 | 08:17 PM
sgtr275's Avatar
My AUX IN turns off my iphone =(
Old Jan 5, 2011 | 12:34 AM
08redevox's Avatar
Good info I will be picking that up soon.
