EZ PEEZY SSS Wing Install on 2010 GSR (from Lancer wing to SSS wing)
So only two bolts is enough to hold it? You don't need the third? I bought this wing off a friend, and he only gave me two bolts with it for each side.
Also, what did you do with the plastic peg things? Just pitch them?
Sorry I haven't been on here forever but if you didn't see me use or mention it during the install then I didn't use it. I don't recall any plastic risers then again I did this install 3 years ago :/
Thanks to the OP. After having my high rise sitting around for over 2 years I finally did this. Not a problem with the lip spoiler as it doesn't touch it.
Great write up, this will come in handy (hopefully) soon!
I just have one question for you (or anyone who knows): How easy is it to disassemble the SSS/GSR/big wing to repaint it? I'd like to remove all the black plastic parts to prevent the painters from messing it up. If it's easy, I will buy any color wing I can find, but if you can't do it, I'll have to keep my eye out for that elusive Octane Blue wing!
Bonus points: Is that a Rexspeed or similar Ralliart lip replica?
Any chance anyone can help me locate the plastic alignment pin and the third bolt? I know where the outer 2 bolts go on each side, and might be able to figure out the third bolt by making a template of sorts, but I'm worried about drilling into the trunk trying to find a threaded insert blindly. Also, I'm not even sure what size/shape the hole is for the alignment pin. Anyone have pictures or know where to get a template/instructions? I mean, if I bought it from the dealer new for 2 grand, they would install it, so there has to be instructions somewhere, right?
