Tomioka Carbon Fiber Hood Dampers
Tomioka Carbon Fiber Hood Dampers for Mitsubishi Evolution X
Price: $150
Tools Needed:
• 10MM Wrench
• 12MM Wrench
Difficulty:
1 (1-5)
Time to Install:
20 Minutes
Installation:
To install the Tomioka Hood dampers for the Evolution X, you will be using 4 existing mounting points/bolts in the engine bay of your car; 2 mounting points/bolts on the fender and 2 on the hood itself. Below are the parts included in each kit.
1. First remove the bolt closest to you on each side of the fenders.
2. Next use the 4 washers and 2 bolts included in the kit to mount the first brackets to the fenders. (Washer Bracket Washer) The bracket marked (L) will be used on the driver side while the bracket marked (R) will be used on the passenger side.
3. Finally, Use the existing bolts from your hood along with the lock washers to secure the brackets on the hood. Like the other brackets. (L) will be on the driver side and (R) will be on the passenger side.
ETS Michael
108
Apr 23, 2014 11:47 AM
elhuberto
Sep 16, 2013 12:05 PM
