Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How to install these shifter base bushing?
Old Jan 12, 2019 | 07:33 AM
Rikou336's Avatar
Seriously guys, I checked dozen of threads for this. How do I install the shifter base bushing? I removed center console, and removed the 4 bolts but there is not enough room to make to remove the stock bushings? Also how do you put the new bushing? From the top or underneath the base?
Old Jan 14, 2019 | 05:38 PM
villajer's Avatar
I pushed the metal center piece of the stock bushings downwards and pried the rubber off with a screwdriver. I installed the metal bushings from under the base. Good luck!
Old Jan 14, 2019 | 05:41 PM
kaj's Avatar
kaj
Metal center comes out first, so rubber can compress and pop out. If like the 8/9 bushings, half on the bottom, half on the top, put the bolt through both.
