Help with wiring Greddy Infometer Touch please?
Well, I am looking at buying the Greddy Infometer Touch (http://www.greddy.com/home/?id=282) and it uses the cig lighter socket for power. I was wondering if anyone would have any suggestions on how to hardwire the unit so I can do it at the same time when I install the boost gauge? Thank you so much!
Instructions from Greddy: Installing the unit. OBD (TYPE) 1. Connect to OBD connecter. 2. Connect the Red wire with the Male bullet plug on the white connect to the Black/White female bullet connector on the cigarette lighter cable. 3. Connect the cigarette lighter cable to the vehicles cigarette lighter socket for ignition power. |
Can this display boost as well?
I dont think so based on the chart provided in the website
wow, this thing looks sexy. the fact it's got data logging sold me. does it do AFRs?
it would be better if it could hook up external sensors like boost, oil temp, egts and a/f.
By the looks of the pictures I can touch my tach on that thing and make the revs go up. Sweet.
I have one and you can hook a WB O2 sensor as long as it supports 0-5v output like the AEM UEGO. You don't have to hook it up to the cigarette lighter, you can connect it directly to your fuse box so you don't have anything in your cigarette lighter.
Originally Posted by SiC
(Post 6686359)
Can you please explain how you connect it directly to the fuse box? |
Originally Posted by skylinegtr35
(Post 6686779)
So there is no ground wire? Is this going to be basically the same as hooking up a boost gauge?
boost, oil temp, and oil pressure are optional add-on sensors for this device. You can purchase the wire harnesses for it. This device is godly.
i just ordered this from touge factory today. cant wait to get it
