I need help with my HKS turbo timer type1
I had installed the turbo timer and everything worked well. One day I was on my house cleaningmy interriors and the turbo timer stop working, the face did not turn on anymoer and it maked a beeping sound every 15 seconds or so. Can anyone help me to identify what is wrong with it?-I have a 2009 rotor glow EVO X GSR
It happen to me also try unpluging the battery
rotor glow ? is that the new color for 2009 |
Where you able to fix it? The exact same thing is happening to mine…
i got HKS turbo timer too.QUESTION:can u guys get the speed signal?can the turbo timer work with the SSS package."i mean i cant lock my car"
The HKS turbo timers, has a mode that it gets totally off the display, moving the button to some side, some times, will going to reactive the display again. Whatever, disconnected all cables, and reconnect everything again, also, confirm that any cable or fuse are not damaged; also be sure that the cable that goes wired to the handbrake is correctly connected. Thanks.
