Driven fab v3 catch can/coolant expansion tank
Has anyone installed the driven fab v3 on their evo x?
Originally Posted by kevin salazar
(Post 11631525)
Originally Posted by jakgal04
(Post 11633154)
I have it, absolutely love it. I'm actually impressed with how much **** it collects {thumbup}
The install was really easy, took me 10 minutes. The hardest part was reaching the bolt underneath the can.
Heres the write up for the install. |
(Post 11633432)
So you know both hoses go from the valve cover to the catch can? Normally it goes Valve Cover -> Intake Manifold and Valve Cover -> Intake. So the little rubber plug goes on the intake manifold and the other on the intake.
(Post 11633455)
This is on an ETS intake, but its the same concept. You just need to put the rubber plug on the adapter on the intake pipe.
https://cimg2.ibsrv.net/gimg/www.evo...f397ee8bde.jpg https://cimg3.ibsrv.net/gimg/www.evo...4227245464.jpg |
[QUOTE=jakgal04;11633466]This is on an ETS intake, but its the same concept. You just need to put the rubber plug on the adapter on the intake pipe.
https://cimg2.ibsrv.net/gimg/www.evo...f397ee8bde.jpg ok I know where it is exactly now thanks for the help But before you took out the reservoir out did you pump the coolant out? Since the kit comes with the pump |
I didn't pump it out, I actually still have the reservoir on my shelf with coolant still in it lol
(Post 11633473)
I checked, but didn't have to. Keep in mind that reservoir is just an expansion tank so it rises and sinks when the car is hot/cold.
(Post 11633519)
(Post 11633540)
So coolant should just flow into the expansion tank by its self?
(Post 11633644)
Yup thats correct. You'll see once you install it theres no way to put coolant in it anyway{thumbup}
So how every how long are you suppose to pump out the what's in the expansion tank? |
