Now it's Officially a Storm Trooper!
Weird, you look like you're running more poke than I am with the same exact wheel specs. Wrapped mine in 265/35/18's too.
What alignment specs will you run after lowering? Even with the stretched tires you miiiight have some very minor rubbing in the rear. Run -2 camber up front and -1.0 to -1.5 in the rear.
Way ahead of you.
Picked up a can for the OEM center caps so I can throw them onto the RPFs. I haven't totally decided on the front emblem or not, but I'm probably going to do that also.
https://www.evolutionm.net/forums/ev...-shipping.html
