Best wheel spacers with stock wheels?
Sigh. As I sat there looking at my car yesterday at a meet I realized just how sunken in the front wheels look with 3* of camber.
I really don't want to afford new wheels right now, so I'm thinking of running a spacer to bring the wheel out. It will have to added benefit of helping my turn in and widening my track for, pardon the pun, the track.
What spacers and size do you recommend? I'm not sure if I want to put new studs in. Frankly I'm not sure I want to run spacers at all...
dependents on your wheel size and tire size. It might will rub. Also i'm not a fan for the spacers. If you do get them , check them vigorously.
I think you better off if you ask around the bottom in the main page where is the rac threads are .
https://www.evolutionm.net/forums/motor-sports-15/
Well it looks like your stock wheel size is 18x8.5 +35 and the most common EVO X wheel size is a 18x9.5 +22 so we'll do some calculations.
Stock wheel size:
8.5" = 215.9mm (round to 216mm)
1/2 of 216mm is 108mm
108mm - (+35) = 73mm
73mm = 2.87"
2.87" is the distance from the top of the brake hat to the outer edge of the wheel.
Common aftermerket wheel size:
9.5" = 241.3mm (round to 241mm)
1/2 of 241mm = 120.5mm
120.5mm - (+22) = 98.5mm
98.5mm = 3.88"
3.88" - 2.87" = 1.01"
So a 18x9.5 +22 sticks out 1.01" (rounded) more then your stock wheels. So its safe to say that if you get a 1" spacer your going to have the same stance. I have ran spacers on my car before and as long as you make sure you torqued the spacer onto the car correctly you should be fine.
Johann @ Girodisc
Stock wheel size:
73mm = 2.87"
98.5mm = 3.88"
Johann @ Girodisc
i just bought some 18x8.5 with a 38 offset for my evo 8, when we test fitted it was rubbing the front calipers when we put a spacer on it was ok do you think i should use the spacers (3/4in) as i thinks its a bit too far from the hub itself.
advice on this please thanks
No you should be fine. I wouldn't go over 1" on a nice car like an EVO but I have 1.25" front and 1.5" on my AE86 which I have drifted on occasion and its worked out fine.
thx for the helpful info! btw, with such setup, can i still stick with the stock alignment?
