Wheel Offset Fitment Chart
#92
I have a evo x with the mr suspension (bilstein/eibach) and was looking at getting a set of weds sport SA-55M's 18x9.0 +20 and Im planning on going with 255's. Will this setup clear everything?
#94
wheels & tires
Ok just wondering witch off set would be better to run! Would like to run a 265/35/18 just not sure witch offset would be better? I looking at Enkei PF07 18x9.5 have the choices of +15, +25, +40? Would like not to adjust camber and not to roll the finders.
This are the wheels
http://www.vividracing.com/catalog/g...=201&sizey=169
Tires
http://cdn-ak.f.st-hatena.com/images...1210195713.jpg
This are the wheels
Tires
#96
#97
hi guys
planning on running 18x10.5 +22 with 265/35/18 rubber
oem struts lowered on HnR springs
rear guards have been rolled.
will there be any clearance or rubbing issues i should expect??
TIA
TIA
#98
wheel help
I need some help. So I already have a wheel from my previous vehicle but it is a 5x100 bolt pattern. I was thinking of just buying wheel adapters but the smallest adapter I can find is 25mm. The wheel specs are 18x9.5 ET38 and the tires that are mounted are 235/40 18. If I were to run this wheel with the adapter on the Evo X, will it poke out too much or will it be flush with the fender? How does the math work on this? Do I subtract 25mm from ET38? Thanks for the input.
#102
I picked up a set of 57Xtremes in 19X9.5 +25. My Evo is lowered on H&R's so about 1.3". I have -2* camber in the front and -1.1* in the rear.
I want to wrap them in Michelin PSS tires. 275/30/19 show a diameter of 25.6 that matches stock. With my current setup can I get them to fit ok or should I step to the 265/30/19's to avoid rubbing.
#103
I have mixed thoughts of the offset to run on my car, I just want people opinions.
I'm about to pull the trigger on some te37 18x10.5 but what offset would be better +15 or +22? I'd like to run Toyo R888 in 285/30 aswell
#104
+22 for sure. 10.5 +15 pokes a decent amount. I don't like the look.
