knocking noise front left?
Hmm. I had a car with bad wheel bearings. Made squeaking noises and knocking noises. When they were replaced the noise was gone so this could be one of ur problems as well. Getting it fixed is alot of $$$$$$$$
alright !!!
i know what it is and i found my problem, i think i didnt drive alot yet but didnt hear anynoise
what i did was jack the car with a car jack take a spray can of lub and spray the cylinders with it until there lubbed up !
and bang its all over ...! hahaha
Maybe the differentials doing the self-check?? All evo's have a clicking noise when the car starts moving within the first 5 seconds.
It is very common problem here in Russia, our roads are much worse then roads in USA thats why we got in touch with this problem a lot time ago. It is gap between the rod and the body of the shock absorber, this problem usually comes out after 20k miles of use. In lots of cases you can drive with it for a long time until your shock will go south.
I know this old thread but i am having a knocking noise coming from my front left. I have new cv joints i also notice if car is in air doesnt make sound, i tried pushing up and down on strut but doesnt make sound. I have 2010 gsr that is lowered.
https://youtu.be/WOhX7qb7UXI
hahahaha this OPs posts are so freakin hilarious I love it.
Anyways the knocking could be from a blown strut or your tie rods rubbing against something. I have also read something before about your brake pads moving out of place which makes that kind of knocking sound. you could also check inside your outer axle boots and see if everything is good
OliveRC
Apr 2, 2017 10:48 AM
tucknroll
May 10, 2016 11:00 AM
