Drivers Side Clunk, Knock, Pop or noise from front
I noted today in a parking deck, the drive was smooth but had a an up and down slight roll, this roll in the drive made the clunk noise a lot, and there was almost no movement in the suspension.
this is actually driving me nuts. standing in the door of the car and making it go up and down makes no noise, it seems only when the wheel is push twards the back of the car it happens as a smooth roll bump would do this.
Ok, I made some progress, Using a large pry bar, we found the strut bushing (top) on the drivers side will move with force (takes a lot like driving a 3500lb car) while the passanger side it solid. So it appears it is the strut bushing after all, although it takes a LOT to see it bad. I will order new bushings and post the results back.
I have the same exact issue as you guys... .i hear it on my driver side front wheel.. it clicks a little at low speed. i was thinking axle or cv joint. I guess i will have to schedule an appointment for them to check out my car too.
i can hear mine when making a left or right turn full lock slow moving, its like clunk clunk sound and its kinda loud,, oh and also when going reverse slow i can feel some vibration and clunk sound,,,
do you guys have this too??? hopefully i can bring it to the dealer this thursday...
Ok, so today i went to the dealer to get my front driver side clicking noise checked out. It turns out my lug nuts weren't tighten/ torqued enough. I usually torque it to 80lbs. Since I run a 5mm spacers in the front the master mechanic recommended me to torque it to 95lbs. Also to check it after every track run.
Anyways the clicking noise is gone.
ok so try that method first check 3 nuts on top of ur spring. If the noise still there, then try to check the top hat nut on the center of absorber, but u hv to remove the rubber cover first. I did my and the noise was gone. then next day i noticed the same clacking noise NOT from my FL , but from my RR. lol... keep it coming....
