Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Upgrading Sway Bar End Links: Is it neccessary?
Old Aug 12, 2011, 08:28 AM
genelee112601's Avatar
Originally Posted by deludedbuzz
Yeah the front involves dropping the front subframe which sounds like a ton of work. I think I remember some people doing it on jacks and not a lift.
Also my friend who had front and rear hotchkiss swaybars now thinks he didn't really need the front.
Hm... Good info bro! Ill look under car tomorrow to check for the front bar install
Old Aug 12, 2011, 03:31 PM
a2b
a2b's Avatar
are you guys having noise issues with the whitelines? I have read on the boards that the whitelines clunk?
Old Aug 12, 2011, 04:07 PM
justin81's Avatar
No clunking so far, but I've only had them in for a week.
Old Aug 13, 2011, 02:15 PM
justin81's Avatar
Just got back from my first autox with the new set up and all I can say is it's amazing. I'm running Whiteline front and rear sways both set at medium on Eibach prokit. This setup has just enough understeer to keep you out of trouble, but not enough to make the car push. The car rotates nicely when you want it to, and body roll is nonexistent. This car handles so well now. I'm impressed.
No damage to the endlinks yet.
Old Aug 14, 2011, 09:55 AM
Nice!! ill go and order the rear first thx again
ill post my Test Experience also
Old Aug 15, 2011, 11:49 AM
deludedbuzz's Avatar
No clunking so far, but it does squeak, but that's probably more my fault than it (I should wrap it with teflon.)
Old Aug 15, 2011, 02:15 PM
RevLimiter's Avatar
Im also thinking about upgrading the RSB and endlinks. But I have also herd about road noises coming from the Whiteline. Is this an installation error or is it the RSB? Does anyone have any tips to avoid any noise from the upgrade? and alos if theres any recommended order when upgrading? ie RSB before endlinks? Rear before Front?
Old Aug 15, 2011, 03:10 PM
GTWORX.com's Avatar
I would say it's installation error....swaybars should not squeak or clunk if installed correctly. Teflon tape helps, but even with just proper lube you should be fine.
- Andrew
Old Aug 16, 2011, 07:33 PM
Just ordered the rear bar
Old Jan 28, 2013, 01:56 PM
MarkRacerX's Avatar
Looking for some feedback, how are stock endlinks holding up w/ RSB and racing?
Thank you!
Old Jan 29, 2013, 09:02 AM
RenleyX's Avatar
For what it's worth I read from AMS that the evo X can have bumpsteer issues, and that the front end links are part of the puzzle to fix that, along with bumpsteer correction link kit as well.
I can't seem to find the article, but mayebe someone else can enlighten us on whats useful for the x in the front suspension area....
p.s.
thanks for the info guys, i got my swaybars installed last year and have been thinking about end links for a while since i track my car once a month
killur
Sep 17, 2016 05:26 PM
maperformance
EvoX 'For Sale' Suspension / Brakes / Handling
355
Mar 6, 2014 01:06 PM
Golfa
Feb 1, 2013 09:16 AM
JBAutosports
16
Jan 12, 2012 05:47 PM
JBAutosports
Evo 'For Sale' Suspension / Brakes / Handling
Jan 12, 2012 05:15 PM
Quick Reply: Upgrading Sway Bar End Links: Is it neccessary?
