Upgrading Sway Bar End Links: Is it neccessary?
I'm about to install a front and rear whiteline 27mm sway bar on my 08 Evo X and I'm wondering if it is really necessary to replace the end links. It's harder than I thought it would ne finding aftermarket ones but whiteline offers them but they cost almost as much as the swaybars. Has anyone had to replace their endlinks after putting on stiffer sway bars? I'll be autocrossing about twice a month. Any thoughts or suggestions would be appreciated. Thanks!
http://www.whiteline.com.au/product_..._number=KLC139
http://www.whiteline.com.au/product_..._number=KLC174
There are several different options for new end links just search the forums.
I upgraded up rear endlinks to SSP ones, with my hotchkis sways, they work great, the fitment was a little tight, due to the sheer thickness of the 32mm bars, but it was worth it. Front ones are fine, you should have no issue with them, but I'd replace the rears while you're under there because chances are you will have to do it anyways.
Racingline Performance Endlinks. Work great especially if you live in the snow belt! Front and Rear on our EVO X MR with Whiteline rear sway. I did break my rear endlinks from Racingline. I had them set too long in length and had them on the stiffest setting on the rear sways. I went up a very steep drive way and "Snap!". Just follow the directions carefully. I have the new rears set at stock length and no problems whatsoever...I've been up and down that same steep driveway every week. I took pics of the broken endlink and sent to Racingline and they diagnosed the problem and sent out my new set quickly. Very responsive CS. No problems so far. A couple guys have broken the Whiteline ones around me.
Thanks for the info everyone! I decided to go ahead and buy the whiteline front & rear end links. I'll see how well the hold up next month when I start autocrossing.
i just installed front and rear whiteline's and I don't know why I didn't do it sooner. Car feels 100% better. I also autox a couple of times a month so I'll let you know how it does after this weekend. It will be the first event with them in, but just on the streets the car feels amazing. I'm running the stock end links right now and have both bars set at medium. We'll see how they hold up.
Will do. That said I also have to wrap the sway bar in teflon, just used grease for now and it's squeaking now. Also wouldn't mind if I can get whiteline to send me an anti walk tab kit (if they have one.)
Also my friend who had front and rear hotchkiss swaybars now thinks he didn't really need the front.
