Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
sway bar setting with swift spec r
Old Oct 18, 2012, 09:25 PM
Freebs's Avatar
I have the Spec R's matched the OEM Bilsteins with the white line sway bar and I have been rocking it on the stiffest setting since day one and love it and I don't ever track my car but I enjoy every on/off ramp ... I am actually looking to pick up the front one now as I am getting board and want more
***EDIT***
hahah sorry I did not see the this was started a year ago oops
But to answer the clunk question, 99.9% chance it is the end links... I have this issue to and found out they are the culprits to the clunking
Old Oct 19, 2012, 08:51 AM
RedSER13's Avatar
Originally Posted by 4B11AWD
Any update on this? So was it the endlinks or springs unseated?
actually both.
i added a spring silencer made by Tein on the springs and it made no noise ever since. i wrapped it around the coil just where the OEM rubber ends. oem rubber is wrapped on the last bottom coil.
as far as the endlinks, wrapping the thread (upper part, attached on the car, not the bar) with teflon somewhat cured the knocking noise, but it's still present.
High_PSI
Mar 12, 2017 08:19 PM
JV21804
Apr 4, 2013 04:14 PM
OG
24
Aug 7, 2012 09:19 AM
MR White
Aug 1, 2011 04:23 AM
keith.
10
Mar 18, 2011 04:40 PM
Quick Reply: sway bar setting with swift spec r
