KW Variant 3 Review
In their defense - although I don't why I would do this - the adjusters on 99% of all Asian shocks are two-way bleeders. Therefore, for the first half or so of their adjustment range, they only have an effect at very high piston speeds, which means no effect on rebound at all and only an effect when you hit a really nasty bump at a relatively high ground speed. They are having an effect, in other words; you just aren't feeling it because you rarely get piston speeds of 10+ inches per second unless you live on a very bad street and drive like my brother.
With that said, Dutch stuff pwns Asian stuff, if you like a good generalization.
I will preface this entire review by saying. These are the best coilovers I have ever used. I've ridden several other brands on different cars before... Megan's, BCs, Godspeed... all that comes to mind but there's one more.
The subjective review. these things during your daily actual feel a bit softer than stock. until you hit a bump... then it's just a sudden flash of pure stiff *** coilover feel. I can't say whether the car handles better or worse. I got back home one day after SCCA ended in Central Florida.
I can't really provide anything objective other than it is a bit lower. I just wanted to share that I am 100% happy with these. fully adjustable is fantastic. they however don't come with any specific camber adjustment. But the lower control arm can handle a couple degree's, which I had to use to correct mine.
all things considered, as I mentioned these are the best coilovers I've ever felt.
Spring rates on off the shelf KW V3s are 8/9 f/r.
You don't get camber plates but you get better coilovers. I did not want camber plates because of noise. If I did I would pay for Vorslag anyway.
Oem hats are problme free, eats up pot holes much better and they are not noisy, keep the tires in better shape (less camber) etc. Also for high camber you need a tire which is accept it - match with it in performance.
Most if the entry level applications, and for use this is the best option.
Camber plates at entry level usually are nothing more then a bling. Which is fine, but really doesn't necessarily.
A decent anology comes to mind. imagine your seatbelt... you pull slowly it moves smooth... but you give it a good tug and it stiffens right up. it's kind of like that.
As someone said, they are 8/9 F/R
The discussion on Camber plates, I can agree they are unnecessary at this level of coilover. your stock LCA can put you at 2.5 degrees and that's more than you need on the street imo. But they can of course be set in plates if you have a need/desire.
As for running an AutoX event... I want too sooooo bad. I'm deployed right now, and on my last break central florida autox was finished already
Glad you made the decision to get a set of QUALITY coilovers. A lot of people buy cheap Chinese made coilovers like the ones you listed plus Fortune and think they're awesome, but that's because they haven't tried coilovers like KW, Bilstein, Ohlins etc etc etc. The difference between a China made shock and a quality made shock will be HUGE on a road course. Glad you like them.
__________________
__________________
edit: I am a pinhead. The compression is trigressive at the softer settings; it just happens to be the reverse of the typical plot: http://www.kw-suspension.com/images/...Statistik2.jpg
Note, also, how they have listed the clicks backwards from what you might be used to.
This is based on personal experience, i've used this coils on 3 different types of motorsports, and still DD on this with a carseat on the back, so what I meant was if your a weekend warrior and daily drive your car and want the bang for the buck save your money and get this coils and I would put this in mid level
Looking at the plots - http://www.kw-suspension.com/images/...Statistik1.jpg and http://www.kw-suspension.com/images/...Statistik2.jpg - I'd say that you'd have no problem at all running 7/7 with stock valving, but definitely wait for Andrew to say something....
