Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Valve cap
Old Jan 27, 2012 | 07:54 AM
Noe18's Avatar
Valve cap
[IMG][/IMG]
Does any has info about this???
Old Jan 27, 2012 | 09:54 PM
Noe18's Avatar
Any1
Old Jan 28, 2012 | 02:05 AM
AFD's Avatar
AFD
No idea where you found a pic of the ones you posted, but if you google "dice valve stem caps", there's like a million different ones out there. Also try those terms in Google Image Search, and Google Shopping Search.
Not 100% sure, but there's probably a way you can DIY from any pairs of dice.
Old Jan 28, 2012 | 07:30 AM
Iowa999's Avatar
Hi. I've already had my tires mounted and balanced and I'm looking for a way to throw them out of balance. I was thinking of just prying one or more of the weights off the wheels, but I'm worried that that won't look good. So I'm now thinking about adding weights to the valve stems. Whatcha all think? Would that not rock hard?
Old Jan 28, 2012 | 11:38 PM
AFD's Avatar
AFD
Do it!
..on the other hand, I'm gonna someday maybe track my car - so I'm looking for the lightest possible valve stem caps out there.
Should I just shave down the plastic ones, or remove them completely? I'm afraid if I remove them, the exposed threads might effect my aerodynamics.
In any case, will I have to get my wheels rebalanced after such extreme weight-saving measures?
DjMarcus
08+ Lancer Show / Shine
Aug 31, 2012 01:42 PM
AWDTerror
Jan 4, 2010 08:21 AM
AWDTerror
Nov 22, 2009 12:03 AM
il2az
Aug 2, 2006 12:35 AM
