DId some suspension upgrades.. question
well I bit the bullet got myself a nice set of KW3 with a roll center kit ( thanks to the suspension gurus here)
Long story short during the alignment , the shop didn't tighten my toe bolt , and during my drive home , it became loose and essentially caused some frame damage. Got it repaired but opted out from the stock rear eccentric bolts therefore I got a whiteline Lateral Link-Adjust Rear Camber Kit , and a whiteline sway bar to complement it.
the only think I forgot to get was Whiteline Adjustable Heavy Duty Rear Sway Bar End Links
I am daily driving and not tracking the car for the next few months.
Is it a big necessity to upgrade these end links right away with this big sway bar?
Thanks.
Thanks.
Thanks.
Thanks.
Was the car making noise with your loose toe bolt? Or was the toe part of the alignment just all over the place? Reason I'm wondering is I'm going for an alignment next week with my new set up and want to make sure everything goes well.
When doing so the bolt has play , and essentially with the crushed washer the washer bent inwards. Also by doing so it made the little rabbit ears bend into the frame.
He quickly showed me how loose the bolt was when he was able to turn it by hand.
So make sure you inspect the bolts after they are done with the alignment
Monkey.Magic3
Sep 21, 2015 07:06 AM
OverBoostedEvo
Jul 1, 2012 09:41 PM
SOUL STEALER
Oct 30, 2011 06:31 AM
