Larger rotors on stock calipers?
I need to change my rotors on my 2010 se. I'm getting wheel pulse under braking, and they're too far to have them turned. I want to go ebc usr, but can't find any info about if larger rotors can run on stock calipers. Stock is 11.6 up front and 10.9 rear. Ebc usr come in 13.8 front and 13.0 or 11.9 rear. Would this work with 18" wheels and stock calipers?
what would be the purpose of larger rotors? And no it wont work because of the braket attached to the caliper would need to be modified. But the caliper is only going to cover so much area I don't see how a bigger brake rotor would really help you at all anyways, without a bigger caliper to back it up.
Get centric/stoptech. Best deal and price to performance ratio. I use the premium solids for street and track use.
Evo 10 centric rotors:
Front:
125.46076 Centric Premium High Carbon Rotor (Solid)
126.46076 Centric Premium High Carbon Rotor (Slotted) - Add L or R in part number for sides
127.46076 Centric Premium High Carbon Rotor (Drilled & Slotted) - Add L or R in part number for sides
128.46076 Centric Premium High Carbon Rotor (Drilled) - Add L or R in part number for sides
121.46076 Centric C-Tek Standard Rotor (Solid)
Rear:
125.46075 Centric Premium High Carbon Rotor (Solid)
126.46075 Centric Premium High Carbon Rotor (Slotted) - Add L or R in part number for sides
127.46075 Centric Premium High Carbon Rotor (Drilled & Slotted) - Add L or R in part number for sides
128.46075 Centric Premium High Carbon Rotor (Drilled) - Add L or R in part number for sides
121.46075 Centric C-Tek Standard Rotor (Solid)
Front:
Rear:
I would be an absolute liar if I didn't admit that it's partially cosmetic because the slots look cool. I wouldn't bother with drilled or dimpled. But I also like that they're completely coated so it wears off where there's pad contact, so it would continually protect from corrosion everywhere else. They're not a crazy amount more than stoptech centric blanks.
I appreciate the part #s. I ended up going with the stoptech slotted. I kept searching for good things about the ebc rotors, and found mainly complaints about ebc pads turning to dust, squealing, or people saying they like them. Centric/stoptech get recommended all the time, so I just went with them. Got both fronts for just over $200.
I'm going to do the rears too, but the fronts are the ones that really need changing. Is it a better idea to wait and do all four corners at the same time, or is it fine to do them separately?
twinturbozs
Aug 25, 2007 08:25 PM
evoLuzN
Nov 10, 2006 10:25 PM
umiami80
25
Apr 22, 2005 05:32 AM
bracer
Mar 13, 2005 02:18 AM
