Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Evo X Sway Bar Endlinks Bolts
Old Apr 24, 2017, 05:52 PM
jzsoarer's Avatar
I would like to know if the bolts loosening on aftermarket sway bar links are still an issue?
I would like to run a square spring rate with a stiffer sway in the rear. After reading post after post of the bolts loosening with the aftermarket links, I am considering going with a higher spring rate in the rear than the front to compensate for running the stock sway bars.
Old Apr 28, 2017, 06:23 PM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Sway bars and springs are not the same thing. They do work together, but stiffer on one is not the same as stiffer on the other.
I've never had an issue with end links loosening up when installed properly.
Old May 8, 2017, 09:46 AM
EvoM Community Team
migs647's Avatar
As long as you use an allen wrench while tightening to spec, they don't come loose. Only real issue is factory end links bending with aftermarket sway bars. That's why some upgrade the endlinks as well.
EvolutionRacing
Mar 21, 2017 11:01 AM
MisUnderStood
20
Jan 18, 2016 05:57 PM
deylag
Jul 27, 2011 06:29 PM
.MM
14
Feb 17, 2007 11:35 AM
Quick Reply: Evo X Sway Bar Endlinks Bolts
